backup sensor problem
Old Oct 10, 2011 | 12:00 PM
RUSTANG67's Avatar
RUSTANG67
My 02PSD F250 has the backup sensors in the bumper. They haven't been working for awhile now but boy do I miss them in a tight spot.
What are the first things to look at to troubleshoot?
Old Oct 10, 2011 | 12:18 PM
ToMang07's Avatar
ToMang07
Short of a good scanner.....
Turn the engine OFF< but key on.
Lock E-brake/block wheels.
Put into reverse.
Touch the sensors.
If they are clicking, they are good. If not, that's the bad one.
Old Dec 30, 2011 | 12:40 PM
erniek70's Avatar
erniek70
all 4 are clicking, but the system is still not working. now what?
Old Dec 30, 2011 | 03:29 PM
radmacks's Avatar
radmacks
I personal tried the clicking test and got nothing. My seems to be related to my trailer harness. They start working for a while just after I have a trailer hooked up multiple times. I'm going to slide under when it gets nicer and clean all the wiring harness up. I have a bluetooth obd2 adapter and don't have any codes is their a specific test or software ?
Old Mar 2, 2013 | 02:36 PM
RUSTANG67's Avatar
RUSTANG67
Are these available in the aftermarket or do I need to go to Ford?
Old May 22, 2013 | 09:41 AM
erniek70's Avatar
erniek70
mine would work momentarily, with a trailer hooked up too. One very quick beep. Do not work at all without a trailer hooked up. Did you find a solution? Are they now working?
Old May 22, 2013 | 09:59 AM
grec-o-face's Avatar
grec-o-face
Anything that's "wrong" in the system can cause it to go to OFF. For example, if the speaker is bad, or if there's a chafed wire anywhere, the system will go to OFF.
My last truck's system worked flawlessly. I ended up wiring a switch inline with the speaker wire so I could force it to stay OFF. It would become a real PITA while plowing or towing.
My current truck's back-up sensor will work every once in a while. I'm in no hurry to find the issue and fix it.
Old May 22, 2013 | 10:05 AM
erniek70's Avatar
erniek70
I already replaced the speaker. Speaker has 12V too it, when in reverse...which I would think means the module is working. All 4 sensors click, so they appear to be working too. Don't know what else to do.
Old May 22, 2013 | 10:17 AM
grec-o-face
The stealerships can plug in (OBD) and monitor the sensors, see what each one is doing. I'm sure anyone with a high-end scanner can do the same. That might be you're next approach. Maybe you've got a sensor that clicks, but doesn't sense????
lionhart94010
Feb 3, 2021 08:54 PM
Whysobig?
May 31, 2011 10:34 AM
PogueFord
2004 - 2008 F150
Dec 14, 2010 05:41 AM
jdpina
Feb 9, 2007 05:19 AM
vettdvr
Oct 13, 2006 06:12 PM
