How to ID
Old Oct 9, 2011 | 07:59 AM
black67's Avatar
black67
Smile How to ID
How do I identify which engine I have in my truck. I was told it was a 300. I have no idea . What are the identifying marks ? Thanks
Old Oct 9, 2011 | 10:14 PM
78f150L6's Avatar
78f150L6
Year, Pictures, and how many spark plugs do you have
Old Oct 9, 2011 | 11:46 PM
F-250 restorer's Avatar
F-250 restorer
I assume you me whether it is a 240 or 300? You have to measure the stroke. With the s.plug out turn engine until piston is at the lowest point in cycle, then put a pencil or something inside the hole until you touch the piston, and mark the object. Then rotate the engine until piston is at tdc, and mark again. remove and measure distance between the marks. A 300 has nearly a 4'' stroke. IIRC the 240 is about 3.18".
Old Oct 10, 2011 | 02:28 PM
black67's Avatar
black67
id engine
its a 6 cylinder 1967 vintage 1 bbl carb.
93 Sidewinder
N. California Chapter
Nov 9, 2007 02:48 AM
Semper Fordelis
Feb 22, 2007 07:41 PM
brianwbo
Nov 27, 2004 10:29 PM
txwing
Mar 31, 2004 03:04 PM
mpenni
Jul 15, 2003 10:26 AM
