Wire Loom on lines?
Old Oct 7, 2011 | 10:12 PM
91 Dually's Avatar
91 Dually
Wire Loom on lines?
OK, I've been wanting to ask this for a while now, so here goes... You know the black plastic wrap on the fuel lines and HP Oil Lines.. I've always called it wire loom, cause I've only seen it on wiring till now... Does it serve any purpose on there? Other than to catch dirt and grime?? I'd like to do away with it if it won't cause problems.
Old Oct 8, 2011 | 07:19 AM
fishmanndotcom's Avatar
fishmanndotcom
lol kinda funny, i was thinking the same thing yesterday as i was reinstalling my FPR and changing out the busted fuel return lines. only thing i can think of is it protects the hoses from possibly rubbing each other and creating leaks.
-cutts-
Old Oct 8, 2011 | 08:14 AM
91 Dually's Avatar
91 Dually
Just thought of something. Maybe they put that stuff on there in case of a leak.. Would help contain the fluid instead of letting it spray all over the place?
Old Oct 8, 2011 | 01:39 PM
fishmanndotcom
maybe if it was all zip tied, i blew mine off. i had diesel all over the inside of the hood, everything was wet.
-cutts-
Old Oct 8, 2011 | 04:20 PM
arkredneck's Avatar
arkredneck
Only thing I can thinkn of is it keeps things from rubbing together as much so if you are workin on your truck and see wear on the wire loom you can try and fix the rub problem or replace wire loom
RA31925
Jun 22, 2011 01:01 PM
Hagerhorrible
May 24, 2011 07:29 AM
natew
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Oct 2, 2010 05:51 PM
Midwest Dually
Jun 3, 2010 10:52 PM
kenpobuck
23
Feb 23, 2010 06:44 PM
