Battery Light is ON -- now what ??
  #31
Old 11-18-2011, 06:59 AM
myblkex's Avatar
myblkex
myblkex is offline
Originally Posted by Stewart_H
Did you also replace the drivers side at the same time?
If not, you should have. Since it was just back in July, you should be ok replacing it now without having to worry about the passenger side, since it's only a few months old.
Stewart
+1 - the other batter got 'wounded' trying to keep you going after the other one had died. Also lucky the alternator didn't burn out.
You know what sounds strange is that ever since I pit in the new alternator - the truck has seemed as if it has much more pep and getupandgo. Anyone else have similar experience ?
  #32
Old 11-18-2011, 08:06 AM
leboyd's Avatar
leboyd
leboyd is offline
I would speculate that the old alternator was dragging because it was always trying to produce. Now that the new one produces properly, it "turns off" and removes the drag. You may see better fuel mileage also.
  #33
Old 11-19-2011, 11:37 AM
gwh1bass's Avatar
gwh1bass
gwh1bass is offline
Same symtoms here. Last year I replaced the alternator with a Ford remanufactured one. Still have intermittent battery idiot light coming on. So both batteries are approx. 2 years old, alternator 1 year old and still the same trouble. I have found that I can play with the "pigtail" to the alternator and get the battery light to go off and you can hear it in the engine when charging resumes. Wonder if its the pigtail or the connector or both.
fordboy2
Modular V10 (6.8l)
03-31-2014 07:01 PM
cghstrojan08
1997 - 2003 F150
13
02-20-2011 03:45 PM
skin052
1997 - 2003 F150
15
08-07-2009 05:29 PM
hdman6
03-30-2009 05:14 AM
lifeztds
1997-2006 Expedition & Navigator
18
06-08-2004 04:23 PM
Quick Reply: Battery Light is ON -- now what ??
