'49 F1 Family Project
#121
I know what you mean, I saw that and it looked so finished! I got excited and wanted to mention it. Then I thought, " He probably knows better, but just in case...! Just making sure! I would expect the same from anybody here.(mentioning safety issues) Lookin good though!
#122
#123
Well, it has been slow going lately due to my work schedule and waiting on parts, but I FINALLY have the front axle back under her. I got everything wire wheeled and painted so it looks good.
As I mentioned earlier, I modified the front spring packs by removing 5 of the 8 leaves. I kept the two longest and the 2nd shortest, knowing that it may be less spring than needed. As you can see in the pic below, it was definitely less than I need.
Looks like I get to put a couple springs back in because the springs invert when I step on the frame and the drag link is not parallel. Since I weigh less than the engine (let alone the front clip) I am pretty sure it will be on the bump stops if I use the springs the way they are.
Right now I am waiting on new u-bolts for my springs. I had ordered some from Classic Haulers (they have some for mono springs that are shorter than stock u-bolts). Unfortunately, they sent me the ones for the rear, which are wider and won't work. As soon as I get those I can put a few leafs back in and then it is time to start on the engine (paint and gaskets)!
#125
Yeah I agree. The stock front springs sit almost perfectly horizontal anyway, escpecially if there's an engine sitting on top of them. I'd put them back. Bummer you got the wrong U bolts. They'll straighten it out.
But otherwise, that looks to be a very clean neat job. The Chassis Saver I used on my frame looks pretty much identical to that.
#126
I just got off the phone with Classic Haulers and I know first hand why they have such loyal customers. They didn't bat an eye about sending the wrong parts. The right parts are going out in today's mail and they are including a return label for the wrong ones. No arguing, no hassles at all!
I was bummed when I found the wrong u-bolts in the box because I had that happen from an off-road supplier when I ordered some for my 2000 Ford. When I called them they insisted that I told them the wrong part # and refused to do anything, so I was out $40. I hadn't even given them a part #, I just told them what size I needed and they told me what would work and sent it out.
#127
Merry Christmas everyone! Today I got my truck back to a "roller" and was able to push it out into the driveway for the first time in a few months!
Here is where it has lived until today:
And here it is finally outside:
Here's a shot with the new tires/wheels on the back. I know they're dated, but they fit my budget at $60 for both rear tires/wheels.
#128
#129
On another note, I was down to my last $100 in the budget. That $100 will be eaten up by the engine gasket set ($50) and a radiator ($?). I have been selling miscellaneous things around the garage/house to raise money, but I have almost run out of stuff to sell. For Christmas my wife contributed $100 and my dad $50, so I may be able to get a windshield and a few smaller things. If worse come to worse, who needs a windshield anyway, right?
#131
#132
#133
#135
Are you still putting in the 52 6 cylinder? I have a 215 in a 52 up back and the mount is at the front of the engine. If you look at the picture of your original mounts the 52 has another set of holes just like you have for the V8 a few inches behind the cross member.
If you need some pictures let me know and I can send them to you.
Paul
Paul
