Electric Trumprt Horns
I mounted a set of Viking Horns on my 16 F350. Each horn has its own - and + wires. The instructions say I can wire the 2 pos together (same for the neg) then connect them to the factory horn plug. After doing so, only one trumpet worked. Double checked all wiring and same result. I than ran both wire direct to battery and they both worked. Retried the factory plug and only one worked. Maybe horn relay puts out 12 volts. Any suggestions?
