1978 351M runs terrible please help!! (Long Sorry)
Old 06-15-2012, 12:45 PM
78aktruckman's Avatar
78aktruckman
78aktruckman is offline
Hello All, I've been a lurker here for quite awhile and finally registered great site by the way! I bought a 78 f150 with a 351M, motorcraft 2150 that I'm having some problems with. Ran terrible when I first got it so I cleaned out the entire fuel system, rebuilt the carb, put on a new fuel pump, and it fired right up ran awesome for a couple days. I was driving home one day and it started stumbling and backfired through the exhaust and blew out my muffler! Limped home and adjusted the carb a little took it to the dump and it sputtered a bit but made it, let it idle at the dump and ran perfect on the way home, went for another trip and ran terrible. I did some searching on here and figured I could have a timing/ignition problem so I replaced the distributor, cap, rotor, plugs, and wires and readjusted the carb, I also cleaned out the EGR plate and made sure I dont have any vaccum leaks. So my problem is it runs great at idle but sputters/stumbles and will not run above idle at all. I really need to get this truck running and I'm sure the answer is on here somewhere but if I could get a few suggestions I'd appreciate it. I'm not familiar with the 2150 at all and I'm sure thats where my problem lies. I appreciate your time.
Thanks,
Gary
Old 06-15-2012, 06:51 PM
Dasher400's Avatar
Dasher400
Dasher400 is offline
I just rebuilt the 2100 on my '78 F250 400 last week after I bought it and stumbled it home.
Alot of things jump in my head as far as your problem goes but I would almost bet there is some crud in your main jets/venturis.
Old 06-15-2012, 08:09 PM
J ballan's Avatar
J ballan
J ballan is offline
Just a couple of questions.How's the compression? Ignition advance? And do you still have any catalytic converters on it? The reason I ask is if you've rebuilt the carb maybe the problem is somewhere els. Good luck.
Old 06-15-2012, 10:16 PM
critterf1's Avatar
critterf1
critterf1 is offline
Check the carb for trash.
Old 06-16-2012, 11:27 PM
mark a.'s Avatar
mark a.
mark a. is offline
Have you put a fuel psi gauge on it ? Could be a problem in the line somewhere.
rustyranger390
07-10-2011 06:04 PM
2010Iron883
02-24-2011 08:43 PM
shotgun_000
06-25-2007 01:40 AM
the kid
11-02-2006 05:02 PM
RexB
06-10-2003 01:15 PM
Quick Reply: 1978 351M runs terrible please help!! (Long Sorry)
