ABS and Advantrac Warnings
Old Oct 2, 2011 | 11:04 AM
2003Navi's Avatar
2003Navi
I went over a speed bump to fast and now I am having issues with the ABS and Advantrac Warnings lights now going off. I went to Advanced AutoParts and the only code that came up was B1234. Any ideas?
Old Oct 2, 2011 | 01:25 PM
alloro's Avatar
alloro
You could've smashed the rear ABS sensor or it's wiring. It is located on the top of the rear differential.
BTW the B1234 code means: Mirror Switch Invalid Code. Perhaps this has something to do with the programming for preset buttons 1 & 2. Try setting your seat and mirror positions again then saving them as presets.
Old Oct 2, 2011 | 04:54 PM
2003Navi's Avatar
2003Navi
How do you know it is the rear ABS Sensor?
Old Oct 2, 2011 | 06:17 PM
alloro's Avatar
alloro
I don't know for sure, I'm not there to inspect it. I'm theorizing that the impact from driving too fast over the speed bump forced the rear axle to bounce to the point of damaging the sensor.
Old Oct 3, 2011 | 06:36 AM
broncoholic's Avatar
broncoholic
Assuming we're talking about his namesake (2003Navi), it has independent rear so the differential is mounted solid to the chassis. Each wheel has a sensor/ring and I'd suspect one of them was jarred loose or out of alignment.
Old Oct 3, 2011 | 08:30 AM
c_hohensee's Avatar
c_hohensee
Was the scanner at Advance able to read chassis codes? If not, you will not see the the trouble code for any abs/advancetrac problems.
Old Oct 3, 2011 | 08:59 AM
2003Navi's Avatar
2003Navi
The only error code was the B1234. No codes for the ABS or Advantrac even though both lights are on.
Old Oct 3, 2011 | 09:11 AM
c_hohensee's Avatar
c_hohensee
Was the scanner able to read codes that start with c (most that auto parts stores have cannot)? If is not then you would not see the code.
Old Oct 3, 2011 | 11:54 AM
2003Navi's Avatar
2003Navi
Yes the scanner is able to read C codes
BlackNGoldRules
1983 - 2012 Ranger & B-Series
Jan 30, 2017 09:24 AM
Ford'05HG
Jun 1, 2016 07:06 AM
TWolf
Jul 18, 2012 05:05 PM
superv10
Dec 3, 2009 10:42 AM
aplustechnician
Jan 13, 2008 04:30 PM
