Sponsored by: Real Truck
good or not
Old Apr 7, 2003 | 06:36 PM
jackal18us's Avatar
jackal18us
good or not
i found a truck that i might want to buy. it is a 1999 F250 5.4, auto, 4x4, ex-cab. it has 93,000 miles on it. it has a snow plow, small sander, tool boxes and a ladder rack. my questions are: first off should i be worried about the milage on it? how do these trucks hold up to plowing? anything serious to look out for? any help would be great.
Old Apr 7, 2003 | 11:59 PM
V10F250's Avatar
V10F250
good or not
As long as the previous ower took good care of it, and changed the oil often, then there is nothing to worry about. Fords motors are pretty much bullet-proof. However, that being said, I personally would not touch a Super Duty with anything other than a V10 or a Diesel. To me, the V10 doesn't even have enough power. As for things to look for, check the front suspension and the front of the frame. If it was abused, then the frame could be cracked, or the suspension will be shot. Then, you will be looking at some serious money to fix that.
Old Apr 8, 2003 | 01:39 AM
SouthernDually's Avatar
SouthernDually
Red face good or not
V10 said just about everything. I would also check to see if there has been any repairs done to the truck. Look at the frame on both ends to make sure that it hasn't been straightened. I have seen several that looked like good deals but when you got to checking closer you would find fenders not aligned properly. frames bent or had some real shoddy workmanship done by a local yokal that didn't have a clue.
I also agree that a SD should have the V10 or 7.3. After all to me thats what makes a Superduty. But each to thier own. Thats why we are in the Gulf again.
God Bless our Troops:
Old Apr 8, 2003 | 09:12 AM
Waxy's Avatar
Waxy
good or not
Don't be frightened off by the 5.4, depending on what your intended use is, it's more than enough engine.
Waxy
Old Apr 8, 2003 | 03:20 PM
jackal18us's Avatar
jackal18us
good or not
thanks for the help. the price is $16995, good? bad? i won't be doing much towing/ hauling if any. but i would need more support for the 5.4 to look into it more. so 93,000 miles really isn't a worry for these engines?
Old Apr 8, 2003 | 03:26 PM
Waxy's Avatar
Waxy
good or not
My brother has a 163,000 kms (~100,000 miles) on his '99 F250 SD SC SB with the 5.4 V8, ZERO ENGINE PROBLEMS, it doesn't even use any oil.
Waxy
