Differential swap?
Old 10-05-2011, 12:45 PM
jcgooden's Avatar
jcgooden
jcgooden is offline
Differential swap?
I have a F150 with axle code 19, which means, I believe, that i have a 3.55 non-limited slip differential. Is there any way I could put in a posi or limited slip dif or would I have to do a whole axle swap?
Old 10-05-2011, 01:21 PM
kedwinh's Avatar
kedwinh
kedwinh is offline
They make Limited slips and lockers for almost all axle types, so yes you can add one to yours. But it would probably be cheaper in the long run if you could find a good used one already setup that way. A limited slip will cost you around $300 and up depending on which one you chose. Then you'll need an install kit and someone to install it if you don't know how which will probably be another $250 or up.
Old 10-05-2011, 06:58 PM
jcgooden's Avatar
jcgooden
jcgooden is offline
Thanks bud
Cfrank89
1999 to 2016 Super Duty
11-05-2017 07:51 PM
Nathan511
12-25-2016 06:14 PM
Pappawheely
01-29-2016 11:53 AM
ol'chebby
10-23-2012 04:45 AM
stephen.south
24
03-05-2009 07:02 PM
Quick Reply: Differential swap?
