7.3 psd white smoke from tail pipe
I have a 2000 7.3. Was passing in traffic the other day and then all of the sudden white smoke started comming out of the tail pipe and filled the cab (yes in the cab freaked me out !). Removed the valve covers, pulled the glow plugs and found excess pypass on #3 and 6. Replaced the injectors. Truck starts and idles fine now. On the other hand there is white smoke coming from the vent on the valve cover. Along with from the tail pipe. Not thick just noticeable.The muffler does have alot of excess oil in it and dripping from the tail pipe at this time. Pretty sure the oil is from the injector replacement. Did clear the cylinders by removing the glow plugs and cranking the engine to clear it out. Just wondering if there is something I am missing. Have not take it for a spin as of yet, did let it idle for about 20 min. with no problems noted on the gages. It idles smooth. Would like the smoke to subside before I run down the street.
Also does anyone know where I can purcahse the hold down bolts fro the injectors? One of them was slightly rounded off and needs to be replaced. Thanks for your tiime.
<!-- / message -->
<!-- / message -->
<!-- controls -->
Can you post a video of the smoke coming out the oil fill tube when the cap is removed? With the engine running, rest the cap on the tube flat side down and see what happens. Hopefully it just vibrates around a little bit (like air hockey...) Puffs of white smoke like a choo choo train is not a good sign...
Keith Leigh
08-31-2018 08:31 AM
tfontaine1
1999 to 2016 Super Duty
11-11-2017 05:53 PM
jeff wilson
06-12-2012 04:48 AM
kitsapcountychopper
25
03-19-2004 08:11 AM
