1995 f150 347 build
#31
what was the power and torque difference over the stock 302? i have the truck in my sig, and its mass air wanting to kind of do the same deal.. ive got a 302 that i pulled out it has all of the bottom end, the only thing that i dont have from it is the heads, rockers an arms it looks just like the pic he posted 1st, im looking at ford racing gt40x heads tho an a more radical cam..
#34
#35
No, I made more changes !! Lol... I threw on some roush heads, Same as world Windsor seniors.roller rockers, ultradyne custom ground roller cam, Bbk throttle body, pro m mass air for 30 # injectors, 30 # injectors, edelbrock upper n lower intake, custom tune. Drive it alot. Still have to gear it though! !!
#36
#38
Still have the HO cam(pt no.)? Is it for sale? Did you like how the 1st build turned out vs stock? My pickup is in great shape and it was taken care of. It runs fine but it is pretty lame in the power dept. Looking at the pic of your 347 shortblock and the flattop pistons used. I was wondering what the static compression ratio was with the stock heads.
Tim
Tim
#39
Yes, were doing my sons 351 in his 92 and will be using that ho cam, e7te heads, etc... the first build turned out very well. Im at 10:1 now and run premium fuel. First build I ran mid grade without any issues. If I was you Tim I would get a 351 from a bronco or something 'roller motor' Build that. The money you save on stroker kit will get you some good heads!
#42
#44
Considering the drivetrain in his pickup... 300 hp and 350 tq at the tires is pretty good for a long runner EFI street setup.
If I use a 351W block I would still have a stroker anyway(393 or 408). I just don't want to hassle with needs of the taller block. I once had a 351W powered 81 Mustang, a blown 90 5.0 and several other old Fords. You 1st combo is what I will most likely end up with.
Thanks
Tim
Thanks
Tim
95beater
40
03-03-2019 10:33 PM
chrisbrown67
15
10-29-2009 11:01 AM
ma94xlt
08-05-2008 09:34 AM
FordF350Baby
01-10-2007 09:12 PM
tstpnb
10-20-2003 11:25 AM
