diesel in coolant
diesel in coolant
I just bought a 2005 f350 6.0 diesel that already had a egr delete and head studs done
I found diesel in the coolant and have flused the system to see maybe the person who worked on it never cleaned the coolant or if its still leaking. I did pull the egr valve and it is damp inside. what problems could I be looking at?
Okay, let's clarify something. You state that you are having DIESEL FUEL (not engine oil) contaminate the engine's cooling system, correct? You also state that you have flushed the cooling system out, but continue to have diesel fuel getting into the cooling system, did I understand this correctly? You go on to state that you just had your head studs and EGR system deleted recently, correct? How long ago? How many miles have been driven since this job was done. Was this a pre-existing issue?
Nope dezal fuel in coolant = BAD Heads
the injector cups are leaking
sorrey man whoever truck this was new it was like this probably dumped the money at headstuds thinking it would solve the problem NOT and dumped it on you
that sucks Sorrey to hear that
how long have you had the truck??
Injector cups are supposed to be replacable but I havent heard of anyone being sucessful from what I get out of it that they usually still leak
thats probably why M-chane recomends new heads
read thru this
read thru this
