Rough cost for shop to replace LPOP & all seals
I have a nagging leak coming from behind the front harmonic balancer. This truck has 380k miles and I'm worried about the LPOP not sure when PO replaced if ever.
What could I expect a reputable shop to charge for replacing LPOP and all related seals?
Book time is 2.7-3.0 hours and the part, from Ford, is around $100 (not including the shop's mark-up). It will come with the balancer hub seal and square cut o-ring for the pump-to-front-cover mating surface.
The variable is the shop's labor rate. It varies by region but estimate between $80 and $150 per hour.
In this post I attached some details about the LPOP from the Ford service manual if you feel you want to take a look.
https://www.ford-trucks.com/forums/1...l#post19613960
