if you are gonna go that rout, then it dont matter. i think that all the manifolds would have been changed for the turbo. plus the exhaust manifold on the driver side is a different length, i think
=Ill get back to ya when i find out tomorrow. I might call Riff Raff Diesel and just ask, theyre up in Oregon which is where the truck is and ask, whats involved in swapping to all that from what he says hes running
The driver side manifold has to be changed and the upipes. Would have to have a custom y pipe if no manifold. The 4r100 is plug and play to obs but you can't put an e4od in a sd. Ad's wouldn't run worth much with a 15*. The weak 17* I had wouldn't. The t 500 will now though.
