4 inch lift with 35's?
i was wondering if 35's would be to big with a 4inch lift.
in a few months im going to have to save up and get a new suspenstion due to mine being shot, so i thought a lift kit would be good. i also need tires in the future to so why not 35's (im 17 and dont care about gas mileage)
could you guys post pics of your trucks with lifts and 35's
thanks
thanks
thanks
thanks
He has an F150 not a F250 You people and your big, heavy duty, big tire fitting at stock height, cooler truck then mine......
Back to the original question. Yes 35s will fit depending on rim width and backspacing. You wont be able to make super sharp turns or have full suspension cycle without rubbing tho. May want to shim bumper out a bit to help as well. Basically if its a pavement queen then yes you'll be ok.
But as Kudofu mentioned, lifts are a pain sometimes and do cause excess wear on things.
i do abit of 4x4ing, im gunna start doing more because more friends are getting trucks, and i do pay for my gas and everything else for my truck.
5.0H! Stroker bumped up to 10.8:1 compression, ported heads, longtubes and off-road h pipe. All the other supporting mods are already in place. Should be done soon (I hope!) as the last time I had the tank out of the truck I got the fuel pump seal **** eyed and it leaks when full and I don't wanna pull it down for the 4th time in a month! That and the ball joints/steering bushings are shot so it makes for an "interesting" ride.
