How long was the truck sitting before you found out you had this problem? You're bound to need at least orings on the injectors at 340k. Have you checked the ipr wire plug and tin nut? IPR may be stuck too. Have you checked the idm for water? Take it off and shake it if you haven't.
No water in idm replaced w/ known good one. Had ipr wire off when I took out fuel filter to clean . O-rings came today going to do em in morning I will pull ipr also and ck o-rings. TY
Getting closer to problem now! Installed injector o-rings got it to fire up. STILL a problem with NO1 cyl. Before I installed o-rings no 1 cyl wouldnt fire so when I replaced o-rings I switched injectors. Now I have oil coming out of 3 sputs where I didn't before still No oil out of no1 sput when running. I ohm'ed out wires from IDM all checked out in spec. NOW my ? is why no oil to no1 cyl? Could it be IDM itself ? My high pressure oil kit didn't come yet.
