6.0 Power Stroke and coolant loss?
09-19-2011, 09:58 PM
on
The engine has begun to consume water. Where the water disappears?
09-19-2011, 10:11 PM
Pull the EGR valve see if coolant in there
09-20-2011, 09:23 AM
Hopefully it isn't water it's consuming but coolant!
09-20-2011, 10:00 AM
Well is it external? Seeing any on the ground?
Park the truck front end down a hill if you can over night then pull the egr valve and look for coolant like Benny said. If you do find coolant you have a failing/bad egr cooler.
It could be Headgaskets.
Check for puking....
09-20-2011, 10:25 AM
Quote:
Originally Posted by
2006powerstroke90
Park the truck front end down a hill if you can over night then pull the egr valve and look for coolant .
Thanks for posting that part Tyler It slipped my mind
09-20-2011, 10:44 AM
on
Where is the EGR valve is located? I have a EGR delete kit installed in the car
09-20-2011, 11:12 AM
There is an egr delete already?
You need to tell us everything thats wrong/been done to this truck.
If it has a EGR delete, what kind?
Green Giant
09-12-2012 08:56 PM
grcutter
08-18-2011 12:24 AM
onuredneck707
07-12-2011 09:34 PM
bigkountry926
06-14-2011 06:32 AM
03 ,
2005 ,
60 ,
antifreeze ,
consuming ,
coolant ,
diesel ,
disappearing ,
f250 ,
ford ,
issues ,
loss ,
losses ,
powerstroke ,
small
