6.2L V8 Discuss the 6.2L V8
Throttle body spacer
Old 01-01-2014, 07:38 PM
JAE88's Avatar
JAE88
JAE88 is offline
Question Throttle body spacer
Has anyone tried a throttle body spacer on a SD with the 6.2? If so, did it help any?
Old 01-01-2014, 08:12 PM
jeepnford's Avatar
jeepnford
jeepnford is offline
Most of that stuff helps separate you from your money. I put an intake spacer on a 5.0 FI engine once to clear some fancy valve covers. It made big claims about all the extra power I would have. I couldn't tell any difference.
Old 01-01-2014, 08:44 PM
JAE88's Avatar
JAE88
JAE88 is offline
I figured that. I had one on my old 5.4 and made 0 difference, but just thought i would ask and check to see if maybe the 6.2 would be different.
Old 01-08-2014, 07:23 PM
BlueOvalJunkie11's Avatar
BlueOvalJunkie11
BlueOvalJunkie11 is offline
i think the best bet for power on these engines is a tuner and exhaust
Old 01-08-2014, 07:28 PM
JAE88's Avatar
JAE88
JAE88 is offline
I have a 5** tuner on the way. Now i just need to figure out what i will do with the exhaust.
Old 01-08-2014, 07:32 PM
BlueOvalJunkie11
what cab configuration you got?
Old 01-08-2014, 07:53 PM
JAE88's Avatar
JAE88
JAE88 is offline
It's a 4 door
Old 01-25-2014, 06:12 PM
Jamie Mendell's Avatar
Jamie Mendell
Jamie Mendell is offline
I did five star 93 performance tune made a big difference on my 6.2 limited also have k&n cold air . This truck rips now
Old 02-12-2014, 11:08 PM
Zecca93's Avatar
Zecca93
Zecca93 is offline
i did a throttle body spacer with an airaid cold air intake for my 6.2 SD..installed em both at the same time and noticed a difference but then you just get used to it so in the long run dosent really matter.. throttle seemed more responsive tho with a little more torque
Old 06-12-2014, 10:56 PM
IKEA52's Avatar
IKEA52
IKEA52 is offline
Hey Zecca93,
What kind of throttle body spacer did you use with your Airaid CAI?
Old 06-21-2014, 03:04 AM
djm1204's Avatar
djm1204
djm1204 is offline
will exhaust make much difference ? DO I need a tuner to get that difference ?
Thanks in advance for responses
Dan
danger-ranger93
1997 - 2003 F150
07-17-2011 10:48 AM
hotrodmerc
07-10-2007 09:53 PM
greenterror
Aftermarket Products
15
04-19-2004 12:45 PM
cgph4693
1999 to 2016 Super Duty
01-15-2004 12:16 PM
99f350sd
07-20-2003 10:10 AM
Quick Reply: Throttle body spacer
