updated interior pics.......
Old Sep 25, 2011 | 12:34 PM
HIO Silver's Avatar
HIO Silver
Originally Posted by williamwilliam
HIO, yes, I run 15X8 front and rear. They are found on alot of ford trucks in the 1964-79 era, torinos, etc. The 60 series puts a little more "meat" in the rear fender wells while the 70 series on the front helps even out the front/rear look from the back which limits it from looking like its running sideways to whoever is behind one of these trucks The trim rings were added by me along with the 1960 ford hubcaps that I run most of the time. The trim rings are 3 inches wide, chrome.
Thanks again.
LOL. I've shared that view! Stock wheels and tires from the back looks like a 300 lb. woman on 6-inch stilettos.
I still run the flexomatic leaf system. i think there is 4 leaves originally??? My mechanic removed the second longest spring from the top, so I have 2 leaves plus the thicker spring that is directly on the bottom in all. As far as the helper springs....that may work......but I dont know if it will effect the outcome of the rear height after installed or not???? If it doesnt effect the height, I may look into adding the helper kit myself later on if I can find out that it doesnt!
Yes, four leaves. ... my rig has an add-a-leaf for when it had a camper. That's worth 1/2-inch if removed.
It'll be a while but I'll get back to you all if that helper kit works out. Only time will tell. Meanwhile, I've been refinishing the 78 donor's RAs, spindles, dust shields, and rotors. Tedious, but it's getting there. Fall and winter will spent parts buying for a full on thrash in the spring.
Old Sep 25, 2011 | 12:46 PM
MIKES 68 F100's Avatar
MIKES 68 F100
william
you might want to edit out your address on that invoice , not everyone on the web is a friend . if you're not sure how just says so and i'll walk you thru it .
Old Sep 25, 2011 | 12:59 PM
williamwilliam's Avatar
williamwilliam
HIO, sounds good. Keep me posted!
Mike, no worries. Those addresses are to my old mechanic. Since then he has moved on and those addresses are no longer valid.
Old Sep 25, 2011 | 01:06 PM
williamwilliam
Originally Posted by elgemcdlf
William are you saying your truck dog tracks?
No, what I was saying is that with all these model trucks, the truck appears to be going down the road "side ways" if you are looking at it from the back. That is caused by the orginal narrower rear end......and that makes the front tires stick out further than the rear tires.....while looking from the rear of the truck going down the road. The 60 series tires I added to the rear wheels with 70 series on the front wheels helps the look from the back of the truck.
grantschim
6.7L Power Stroke Diesel
Jul 26, 2011 10:16 PM
Last Chance 56
27
Sep 6, 2010 11:31 AM
VoodooRacer
2004 - 2008 F150
Feb 6, 2010 07:54 AM
Fontucky Slim
Nov 17, 2009 09:16 PM
z71burb
Oct 15, 2007 06:05 PM
