'52 problem stalling
Ok I just got my '52 back today after having it painted etc- Driving down the road on the way home, about 6 or 8 times it starts to jerk (as if I was stepping on the gas and taking my foot off again and again) and if I didnt pull over and stop, it would stall out. It wasnt happening when I was accellerating per se, just as I was going down the road at a steady pace. I even tried slowing down and dropping it into second, but it continued t do it. When I'd stop and then start out again, its fine for a while but then does it again.
Engine sounds good when its running, Carb is new, fuel line is fine, nothing was dripping or anything when I reved the engine, everything seems to be fine. Any suggestions on what to check/ what the problem might be?
Thanks
Darren
Thanks
Darren
Do you hve any fuel filters in the system? You should have one from the tank to the fuel pump and from the fuel pump to the carburetor. Check them. They may be plugged up. If they're metal or plastic filters, remove them and tap it on the ground. You may see the junk come out.
Similar thing happened in my Airflow a few years ago. It would rev and drive fine, but as soon as I let it coast, the car would eventually die. The first time it happened, I thought I ran out of gas. The second time it happened, on the same trip home, I knew something was wrong. I limped like this for a few miles until I got home. I removed both fuel filters and both were gunked up. Replaced them and no problems.
Crazy things happen. I've often told the story here about having a plastic price label swirling around in my gas tank. It probably came off a bottle of additive or heet. From time to time it would float over the outlet and shut things down. As soon as the suction was stopped it would float back off and the truck would run normally - until it did it again.
Intermittant hesitation like you describe - tank off so often I could remove it in 10 minutes and have it dumped into 5 gal buckets. Finally saw the little sucker floating in one of the buckets - tough to see cause it was clear.
May not be your problem, but it might help somebody else and worth keeping tucked away for reference.
Thanks for the suggestions- I'll have to check out the fuel filters and see if that's the problem- My buddy kinda thought the same thing-
I put gas in it on the way home, so there isnt anything like tape under the cap. They guy who painted it noticed it first when he drove it around the block after he replaced the king pins.
Thanks
Thanks
I think the point is, there may have been tape or cardboard on the filler, that fell into the tank when being removed. Shine a light down in the tank, you never know what you'll see...
For months I been bitching and moaning about my truck running like crap.
Bought new parts,got my carb rebuilt.
finally my truck was running better...for a week.then:
it started stalling again...
someone on FTE suggested to check the tank.
I thought to myself:"I just cleaned the tank last month,it was clean,no rust no nothing".My fuel filters were clean so I dint blieve the tank was clogged or something was floating around.
Yesterday My truck stalled again so I decided to check the tank.
I tried to drain the gas from the tank with the drain plug under the cab and nothing came out.
I disconnected the fuel line and nothing came out.
I stuck a paper clip up the little hole and gas came gushing out.
Took the tank out and found a soda cap in there.
took the cap out and cleaned the crap out of the tank.
Put gas in there and tried to drain it and nothing came out.
I had to take the whole drain assembly to find a clear piece of plastic that fit perfectly in the drain plug and it was not letting gas come out.
Installed tank and put gas drove for a mile and IT STALLED!!!!!1
Finally I just put a new fuel line and found out a bunch of junk in the old line.
I was lazy and didnt believe this guys They could have saved me alot of time and money....
BTW.:If ya want to work on yer truck,dont lower it unless you use airbags or have a lift in yer garage
That's why I've had a locking gas cap on my truck since i put it on the road. Also after the label fiasco I made a roll of metal screen about 1 1/2" long and stuck it in the outlet, effectively creating a stand pipe. Crud and debris has to be pretty big to cause problems now.
im gonna steal your idea.
Locking caps look so ugly tho
Check out these:
Fuel filter screens Petcock filters Triumph Norton BSA | eBay
Almost all motorcycle pet***** have screens like these, that press into the inlet of a petcock.
Check out these:
EDIT: I found the fuel filter that I bought. It's a Mr. Gasket 9706 Universal Clearview Fuel Filter. http://www.amazon.com/Mr-Gasket-9706...6410984&sr=1-6. You can also purchase replacement screens - Mr. Gasket 896 Fuel Filter Element: http://www.amazon.com/Mr-Gasket-Fuel...gy_auto_text_b
Another brand is available, which is slightly cheaper. It's a Spectre 2369 Universal Clear View Fuel Filter: http://www.amazon.com/Spectre-2369-U...6410984&sr=1-8. Replacement filter screens are also available - Spectre 2358 ClearView and Pro-Plumbing Fuel Filter Replacement Element Kit: http://www.amazon.com/Spectre-2358-C...gy_auto_text_b
