1996 f 250 4x4 Help!
Rides very rough new 285 16 tires 8 ply 50psi new front shocks, 140,000 miles on truck. aprox 2 inches between front springs and bump stops. Negetive arch in front springs. Ive been told i need new front springs and i believe it but how do i know for sure? 7.5 and auto thanks
Also, is it possible to mount these upside down? I'd check that too....
The Dana 50 TTB axles have negative arch springs. Don't worry about that. If you mean that it seems like it lunges when you hit bumps, thats what those axles do. Personally I hate the design of them and I find them to be really weak, so I swapped to a Dana 44 straight axle. That spacing isnt a big deal either. A big block weighs more than a small block and they used the same springs for both so thats typical. Its all just the design...the terrible, TERRIBLE design.
Mine hits pretty good on bumps too, so much so that having an open cup in the cupholder is a bad idea. Mine sat level with a 28' 7500# trailer hooked up to it, the same trailer made an 08 Chevy 1500 sag really bad. 250HDs are designed to haul and pull so they have thicker, harder spring packs. The Bronco isn't designed to be a hauler, so it has lower spring rates for a better ride.
My 0.02 USD worth . . .
My F250HD 4X4 has reversed arch front springs, too. That's normal.
With 235/85-16 Duratracs, it has been known to skitter when crossing bad sections of pavement on 680 freeway, empty or lightly loaded. Those are ones that would swallow a VW bug whole. Rough ride is normal, too. These are not sissy trucks to cruise the mall with - they are real trucks meant to work hard.
Admittedly, the reversed shackles in front do not contribute to a smooth ride and the TTB having to twist the leafs to articulate doesn't help, either. Of all the Fords, this is possibly the roughest riding one of the lot. Still wouldn't trade it for a Coupe Deville.
You do have to work with the tire pressures because running the recommended (full load) 50/80 frt/rear will wear the centers of the tread badly running light or empty. I'm running more like 40 frt and 55 rear. Tread wear looks good, too.
Ray
Ray
Ray
Ray
It took me awhile to figure out the tires, and I'm still playing with the pressure. I'm on my 3rd set of used tires because my fronts kept wearing funny. My latest set are in great shape, and I'm hoping I have the pressure right, because I like these tires. Once I can confirm they are wearing right, I'll buy a brand new set, just like these.
If I had wanted a truck that rode better, I would have found a 150, or a Dodge...But we needed a stronger, more capable truck that we didn't have to worry about killing the suspension with overloading.
My old farm truck, which is still in service in southern Ohio, is a GMC K3500 flatbed. If you think the F250 is a horrible ride, you need to ride in one of these! The only time it's smooth is when it's towing a load of livestock...even then, it's not a friendly truck. That was back when GM actually made a decent work truck! I've had it loaded with over 2-ton of payload and it still doesn't squat much.
Basically, if you want a softer ride, you'd be giving up load capability.
Replacing all the bushings won't soften the ride, it will actually stiffen it up a bit.
Air down the tires a bit, and keep about 800 pounds of sand or concrete bags in the bed, and it WILL be more comfortable...just keep an eye on tread wear.
