Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
- Why is My Power Window Not Working?
Guide to diagnose trouble and recommended solutions
POWER WINDOWS & RADIO electrical problem
#106
#107
#108
Just had this happen on my 03, Nothing seamed to get it working until I pulled fuse 35. I pulled it out and put it back in , once I put it back in I heard the relay click and everything worked. My truck is in storage but I have been checking it everyday and as of now it is still working. Snow have you dove into yours yet?
#109
So my soldier repair worked for about 2 days, then it went south again. Im thinking what actually "fixed" it was me flexing the board when i took it out of the cluster housing. I brought my new vcm2 home and checked for codes. Even when the cluster was dead it would still communicate with the scan tool. I got a code for over voltage in the instrument cluster codes, so i checked the pids and the cluster thought the battery voltage was around 18 volts when it acted up. I could flex the cluster connector on the right(blue i think) and squeeze it between the back and the cover and watch the voltage reading go from 14.2v KOER to 18+volts. So apparently the volt meter on my board was messed up, and since i couldnt find a circuit board diagram for the cluster i just replaced the whole thing with a ford reman. Its working great now. So my issue was the cluster protecting itself by shutting down because it though the alternator was over charging.
#110
Mine has been acting like a good X all this last year so I haven't had the itch to look into it yet.
From all I read it seems the relay in the gauge cluster is the fault. If I do run into more problems with it I will definitely be looking for the relay.
#111
#112
New excursion owner
I PICKED up a 00 Ex 7.3 a few days ago. Having some of the same problems. With the engine off and Ignition on, the lights go out when I hit the power window controls. ALL of my windows are very weak like the battery is almost dead. Is this the Battery Saver Relay. I pulled the fuse panel and noticed the cover was off of the relay that is top left. I didn't notice any modifications to it, but i'll check that out. My problem is NOT total loss of function so it appears to be a bit different. Any suggestions
#113
#114
Sorry I can't be of help, but i'll bump it to the top for you. I discovered one of the issues for EX was that 3 wires in the boot between drivers door and cab were broken. I still have issues after rain. I've got to find where the water is coming in. My AC blower came on after a rain and ran the batter down. Nothing I did would make it go off. I turned the ignition on and I could switch it off. CRAZY STUFF
#115
#116
For the Excursion, ours is a relay inside the instrument cluster. Not sure about the Econoline vans, but it could be the same?
#118
Good luck and happy and safe 4th to you.
#119
2005-07 Ford Super Duty Instrument Cluster Repair | CBM
Here's the link to our 02-04 service:
2002 - 2004 Ford Super Duty Instrument Cluster Repair | CBM
__________________
We specialize in repairing and rebuilding circuitry in automotive modules. By repairing these components, CBM offers customers an alternative to high cost replacement parts and a timely solution for malfunctioning vehicles.
Visit us at www.CircuitBoardMedics.com or call us at 800-547-2049.
#120
I just wanted to let you guys know that we have replacement clusters available for the 05-07 trucks for exchange now that come fully programmed for your truck. The mileage and engine hours will remain completely accurate. Here's the link to our service and exchange option if you need it:
saving this as $ seems reasonable and mine from time to time does this as well with no power to windows or radio...
