Starter Solenoid Relay Question
on
The I terminal was discontinued in 1980, as this circut was placed into the ignition switch wiring instead.
The factory installed solenoids will not have an I terminal, 1980-1986, but the replacement Motorcraft ones will have a I terminal, because it can be used on a plethera of different year models, cars and trucks.
The difference in starter solenoids depended on Engine size, and charging system (IE: Battery cranking amps).
The Smaller style in post three was used with the smaller engines with lower cranking amps required.
The style in post one was for the larger engines, or with optional batteries and/charging systems that had higher cranking amps.
You can swap the "post three" type, with the one pictured in post one, but wouldn't do it the other way around.
kr98664
23
02-15-2020 10:24 AM
stiffmyster
04-06-2004 10:28 PM
