My new observations when towing heavy/hills
Old 09-18-2011, 06:16 PM
Hd05's Avatar
Hd05
Hd05 is offline
I too tow heavy and I applaud your review of our engine brake You are spot on. With heavy loads it is a dismal failure. I have posted similar results in my towing experience and received correction from many that I didn't know how to use it or I was going too fast or whatever. Truck is rated to tow GCW of 30k. Stopping 30k needs to be factored into that rating.This is a serious flaw and an obvious over-sight on an other-wise great truck. Hope Ford is listening.....
Old 09-18-2011, 06:34 PM
Painted Horse's Avatar
Painted Horse
Painted Horse is offline
Received 2,558 Likes on 729 Posts
Originally Posted by porthole
How heavy?
The technology is already here, just need to be implemented.
I know it is not the same, but the trucks I drive are over 70 K, with both Telma retarders and Jake Brakes. They will assit braking down to about 10 MPH. Jakes are user seletable between high, low and off. The Telma's off and on only.
I'm not making any comparisons between our light duty trucks and Heavy Duty trucks capable of 70k. Jake Brakes and the other products available on those trucks are in another league. My comments are totally limited to using Light Duty pickups in their OEM dress or the 2000-2007 engines with PAC or B&D Exhaust brakes.
The trailers I pull with my SRW truck max out at 16,000bs. And most are around 13,000 lbs. And I understand that if you are towing 19,000lbs you have the same exhaust braking that I have towing 13,000 and that may not be enough for your load.
Old 09-18-2011, 07:14 PM
porthole's Avatar
porthole
porthole is offline
Originally Posted by BCooke
porthole,
Where NE of Carbondale?
Rt 6 out of Carbondale to 171 to 371 to 247
Neither am I, just an observation. Stopping 30K should be easier then 70-78K.
Agree, 6K more is substantial. And the truck is rated to tow 22.5K
I'd have to really lighten up the truck to tow that though. When I weighed in at 19K the total was just under the max GCWR.
Tool box, tools aluminun roll cover, firewood and stuff - I don't know how an F350 DRW could tow a 22.5 trailer. The truck would have to weigh 7500 pounds - which it doesn't
Old 09-21-2011, 02:20 PM
doczenith1's Avatar
doczenith1
doczenith1 is offline
Originally Posted by jim48
Just one observation. The engine brake works when NOT in T/H as well. At least it does when empty. I know this on account go down a grade to my daughter's house twice a week on the interstate. The transmission downshifts on it's own every time without being in T/H when the cruise is ON. The first time it did this I didn't even know it until I got to the bottom and it upshifted. I since have noticed it does it every time at the same place. I have no idea if it does this when towing, as I set up for the downgrades well in advance(T/H engaged, speed reduced, brake pedal tapped). Of course my engine is different than you guys, just a puny 300 HP.
I'll second this. While driving down a hill with the cruise on and NOT in T/H I decided that I was going faster than desired. I clicked the - button on the cruise control a few times and the engine downshifted from 6th to 4th and slowed me right now. I'm not sure if it was using the engine brake or just normal engine compression but it sure slowed the truck down in a hurry.
Old 09-21-2011, 03:00 PM
720Deere's Avatar
720Deere
720Deere is offline
Not when the vehicle with 70-78k has 20 times the braking potential of the the 30k vehicle!
Dcope17
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
19
09-14-2018 10:54 AM
jcape1
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
08-12-2013 07:49 PM
ramrod7373
06-09-2013 07:21 AM
Ex'ed out
05-21-2008 07:52 PM
rfont54
1997 - 2003 F150
01-03-2007 08:18 AM
Quick Reply: My new observations when towing heavy/hills
