The Ultimate Super Duty Picture Thread.
#526
They punched the key lock out in the passenger door. They must have used something to bust the lock on the ignition b/c when I found it I could turn the ignition w/o a key in it.
New alarm installed already. Have hose clamp on tailgate until I get my McGard tailgate lock. Shop that did the work is painting some door handles to color-match the truck. I am ordering Jimmi Jammers and will have them installed when they put the new door handles in. Oh, and the passenger door is key-delete.
Did you ever look up the door lock FIX thread on here? I used that on my passenger door actuator and it works perfectly!!! I was afraid to go w/o the key lock on the driver's side. In nine years my battery never failed but I KNOW once I remove the door locks from the doors that WILL happen to me!!!
#527
#528
When they took mine, they punched out the door locks...then took a screw driver to the ignition and basically twisted it out of the column. Since I've got the keyless entry pad on the driver's door for my truck (as well as the FOB) I'm really thinking about using the punch plugs Clay offers at RiffRaff. My thought is, if the truck can start it's self it will have more than enough power to unlock the door. If the batteries are going bad, you should have starting issues before it gets to the point that it won't unlock the door(s). Of course for me...the best anti-thief measure is not taking the truck to KC again.
#529
Yeah, I live in a very safe area....but I've been wrong before. Do you need a FOB to get a remote starter installed? I'm thinking of just getting a remote starter and alarm system installed instead of paying a stealership for a new FOB set.
If you can't get into your truck good luck popping the hood to juice up.
#530
#531
#532
This unit can even get an upgraded module so that I can use it with a smartphone app. Sounds pretty cool, especially if you allow kids to drive your truck b/c you can set an "allowed" perimeter and it will alert you if that is broken, same with maximum speed; set the number and it will alert you if the truck exceeds it.
I believe the most important part, however, would be tracking your vehicle in the event it was used without authorization!!
#534
I found a brand new OEM set on Ebay. We worked out a deal and I get them shipped for $350 total. Insurance paid for it but I had to try to save money on things where I could so I could get other parts of the truck fixed while it was in the shop.
For example all five clearance lights had a substantial amount of rust around/under them. Never noticed until the truck was sitting on the ground and then I could see it!!! While the truck was in the shop, I gave them some extra to fix that kind of stuff!!
All totaled the repairs (bodywork and mechanical) were well over $9k. I STILL cannot believe they didn't just total it!!!!
#538
Received 5,149 Likes
on
#539
#540
on
