1951 F1 Front End Lowering
Old 09-19-2011, 09:00 PM
1951flatheaddave's Avatar
1951flatheaddave
1951flatheaddave is offline
Hello everyone, I am getting ready to do the spring over axle drop in the rear and was wondering what was the best way to lower the front to match the rear drop? I am going to use the TCI Leaf Spring kit for the rear since it comes with all new leaf springs and seems like a complete kit for the rear. I saw LMC truck sells front lowering springs but wasnt sure if that was the best way to go. What have you done?
Thanks, Dave
Old 09-19-2011, 09:22 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
Jeff and Nicolle is offline
Hi Welcome to FTE! I have a Jag IFS under the front of mine, but not on the road yet, not even close! I know there are lowering leafs, there are also lower axles, sort of a drop spindle built into the axle, and you use something different with the tie rods. Sorry for not knowing, but someone will chime in soon to fill in the blanks for sure!
Old 09-20-2011, 12:49 AM
arrowheadfred's Avatar
arrowheadfred
arrowheadfred is offline
IFS or stock drop front axle I got the same rear tci spring setup with a tci muxtang 11 IFS. DROPS it 4'' front and back. Drives great !!!!
Old 09-20-2011, 12:56 AM
arrowheadfred
pic. of my truck
It will set like mine in the pic. Note ifs with stock spindels not droped spindels.
Old 09-20-2011, 05:23 AM
1951flatheaddave
Truck looks great!!! Where can I get a drop straight axle?
Old 09-20-2011, 07:27 AM
Jeff and Nicolle
Old 09-20-2011, 08:19 AM
flaharleyguy's Avatar
flaharleyguy
flaharleyguy is offline
Very nice stance! BTW the sun visor you have any info on it> I would like to get and install on my project as well. Thanks
Old 09-21-2011, 12:09 PM
Fordman49F1's Avatar
Fordman49F1
Fordman49F1 is offline
Contact Sid here about drop axles...from what I have been told through my searches for lowering solutions, he is the best in the business and he uses your stock Ford casting. Good stuff.
As mentioned, you are looking at IFS or drop axle to lower it that much. You can get a few inches by using saggy old springs and remove a few. There is a thread on the HAMB right here that talks about lowering...it is a must read for any F-1 owner that wants to lower their truck in my humble opinion.
Good luck!
Old 09-21-2011, 12:46 PM
1951flatheaddave
I am about to order the Posie front Super Slider springs. Good idea or no?
Old 09-21-2011, 01:23 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
I would do a little more research on the Posie springs - I've heard a number of yes and no's on them
Old 09-21-2011, 01:25 PM
Fordman49F1
I'm tellin ya...read that article on the HAMB...it talks about a ton of options he made and why exactly he made them.
Old 09-21-2011, 01:27 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
Don't you have to "C" notch the frame to do a spring over drop in the rear?
Also there can be steering linkage issues with the dropped axle - You need to satisfy yourself that you can deal with these.
Old 09-21-2011, 01:42 PM
Fordman49F1
You actually don't even need to do a spring over to drop the rear...
And yes you do need to get tie rod end drops if you lower the front end over an inch I believe.
Old 09-21-2011, 03:34 PM
ZOOT's Avatar
ZOOT
ZOOT is offline
Drop spindles or dropped axle will require changing the steering geometry. As mentioned before tie rods, and the drag link will no longer be parallel to the frame. Not good for handling and won't improve ride quality. If you have the $ an IFS set up is much better. I dropped the rear by the leaf springs below the axle and an IFS in front.
free72
12-19-2014 06:21 PM
jozan
06-06-2012 08:45 PM
chappys4life
07-14-2009 08:39 PM
PabloSantana
08-10-2008 07:25 AM
84f150man
03-01-2007 12:13 PM
Quick Reply: 1951 F1 Front End Lowering
