rev-x or hot shots..
#46
i was not having a stiction issue at all but i have close to 200k on the truck and figured id do it as a precautionary measure maybe hit it before it started or just as it was starting...i ordered the Rev-x proving kit though as i thought it would be cool to send in some oil and see the wear condition of the engine....although im kinda scared it might come up with somthing i dont wanna know...lol
#47
#48
Received 1,447 Likes
on
This is where it is like my EGR Cooler argument. Your experience is a statistic of 1. I have known far more people that have had less then steller results from either Rev-X and/or HSS. I can count on one hand how many that didn't have to do anything drastic with their injectors after using either one (or in one case both) of those products.
I do however agree with you assement of HSS.
Ford 6.0 Powerstroke cold start before and after adding Rev-X - YouTube
Here's a sample of 1 user who had success using Rev X.
#49
Did you mean to say that anytime a stiction problem wasn't fixed by an additive it was due to a "gross mechanical problem with an injector"???
Just wondering because the way it was written makes it look as though no additive ever worked, that or every stiction issue is caused by a gross mechanical defect in the injector...
The simple fact is that the forces leading to stiction are a constant from the day you start your truck. A varnish builds up and unless treated with something a whole lot nastier than RevX/HSS (which just masks the problem) it will continue to build up and baring replacement for some other reason that injector will eventually have to be replaced. RevX and probably not HSS (pending results) will never cure the problem RevX/HSS is only capable of masking it but the varnish will continue to build under the mask.
#50
on
Just wondering because the way it was written makes it look as though no additive ever worked, that or every stiction issue is caused by a gross mechanical defect in the injector....
1. synthetic oil (requires continued use)
2. Rev X (requires continued use)
3. Inductive flash
Each of these items indepently solved my stiction problem, but I chose to go with the Inductive flash because of simple economics. A one time $100 investment at the Ford shop got me the inductive flash and has solved my stiction problem to date. If I had varnish causing this stiction at 85k miles I would think at 160k miles I would have more varnish causing more stiction problems, however my truck runs better than ever since the last flash.
Also if stiction was caused by varnish I would think a repair procedure would have been developed to simple remove this varnish, but this is not the case, and I don't by the HSS stuff that claims to remove varnish.
I think a polishig effect is what's causing spool valve to stick!
#52
on
You know Troy, I seem to want to recall that you had some extended oil changing intervals. Have you ever considered that could be some of your issue there?
Also, one reason why I'm not an additive fan, that some oil additives have been known to change the viscosity of the oil and that can affect it as well.
I don't know about your idle times or how you cold weather start it. It gets pretty damn cold up in Plano, about as cold on a occasion as it gets up in the hills of TN, but I don't know about Katy. But any cold starting can develop the issue just extreme ambient temps contribute more.
If that's the case, then we are spinning our wheels with this discussion. That is possible, but also stiction issues can lead to some pretty nasty things on their own if whatever was used to treat the issue didn't work. Stiction is actually quite a bit like the EGR Cooler issue and not fixing the Oil Cooler while taking care of the EGR Cooler. Because of that, I don't think Ford actually recommends swapping out injectors until the root cause is figured out. Especially considering the most common causes of stiction can affect the new ones as well.
To clarify my statement I'm saying that some people who have injector problems who think it's a stiction problem and go buy some Rev X and when it doesn't work they report it didn't solve their stiction problem when in fact what they really have is a major injector and/or FICM defect that no fluid will fix.
#55
on
jimmyv13,
Sorry I don't know. If the reason your asking is to obtain the Inductive Heating flash, your Ford dealer should be able to get you upgraded to the latest flash (Includes Inductive heating) at a cost of $100.
I highly recommend it.
#56
on
The last 5 oil change intervals I've been going to 6,500 miles to do some tests on three different oil brands. Prior to these tests I've changed my oil religiously every 5k miles.
I don't know about your idle times or how you cold weather start it. It gets pretty damn cold up in Plano, about as cold on a occasion as it gets up in the hills of TN, but I don't know about Katy. But any cold starting can develop the issue just extreme ambient temps contribute more..
#58
on
BTW it's good to see your activity level up on this forum...
#59
Tex, just over 75% of RevX is just plain ol' mineral oil and a common 'additive' so figure 3oz of mineral oil and just under 1oz of actual product held in suspension so the viscosity change when 3oz are mixed with ~4gallons is insignificant.
#60
on
Summer time is horse show season, it's starting to die down a bit, plus I started doing some work on the side totally unrelated and that angle has taken off a bit as well. Both of those things ate up a lot of time that I had over the last few months.
Y'all can't get rid of my that easily. Life sometimes sucks that way though.
High Binder I agree that is insignificant. When I hear the word additive though, that's just something that comes to mind.
