Possible to weld on valley pan???
I don't have a turbo... But having used the Blue RTV I can say it's utter crap. It will never fully cure(it's not intended to), so all it does is act like a heavy grease or something. I actually cannot think of an application on an engine you'd use it for. However, maybe it's good for marine applications where you want to keep water out, but not make a semi permanent seal?... No idea.
Blue=no uses for me. (and it sealing your rear diff is fine because it's still really viscous stuff so with a lot of surface area it'd work fine)
I've always used orange or ultra black.
Hope it works out for ya, little stuff like that it really annoying.
-Joshua
-Joshua
when my valley pan had a leak in the passenger corner of it i could not find where it was coming from. at night time with a flash light it appeared i could see a little path of oil running down the seam of the head. i followed it up and took a mirror out and sure enough, it was the valley pan leaking in the rear. not sayin thats your problem but its worth a check. glad to hear you got your first problem figured out!
nossliw
62
07-05-2012 12:33 PM
rkymtnman30
03-15-2009 02:25 PM
covrace
11-17-2003 05:00 PM
