Which oils to use?
Old 09-22-2011, 02:38 PM
49truck's Avatar
49truck
49truck is offline
Which oils to use?
Are there any modern oils recommended to be used for the engine, gearbox, rear axle and steering box on my 1949 F3?
I have the oil specs from my original workshop manual but wondered whether developments in oil technology now gave more suited lubricants?
Thanks
Old 09-22-2011, 03:43 PM
old_dan's Avatar
old_dan
old_dan is offline
I'm a believer in modern synthetic oils for the transmission and rear-end. Lucas makes some GL-4 and GL-5 equivalent oils.
For the engine, there are several options. Modern oils have the zinc phosphates removed....your older flat tappet engine relies on that as an extreme pressure agent to protect the cam and lifters. Even the diesel oils have it removed now, so look for a racing oil that contains either Zinc Dithiophosphate or Zinc dialkyldithiophosphates (ZDDP). Valvoline makes one now and so does Brad Penn and Royal Purple (not all of the Royal Purple oils have added ZDDP, so watch out there). Another option is to buy some good oil and add a ZDDP additive. I found the Valvoline VR1 in both a synthetic oil and a straight petroleum oil...that seems to be the best deal, but stores seem to be stocking some unusual viscosity oils, so you may have to shop around or ask them to get a case for you if you want 30wt or 10w40.
Not sure on the steering box.
Dan
jwitty
05-05-2018 05:24 PM
lifted77f250
06-10-2010 04:13 PM
johnkirk
1997-2006 Expedition & Navigator
04-18-2008 03:09 PM
JohnAW
Oil & Lubrication
09-25-2004 11:16 PM
sledhead999
12-05-2002 05:47 PM
Quick Reply: Which oils to use?
