Radio on by itself, now drain on battery? - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-15-2013, 05:53 PM
bourbondog
bourbondog is offline
bourbondog is starting off with a positive reputation.
I had this happen to my 2004 Ford Escape. Replaced the Accessory Relay (NOT the Accessory Delay Relay). I purchased Standard V13081 RY612 for a total of $15.61. After three days, all is still well. Worth a try!
Old 10-05-2014, 08:35 AM
Swantastik
Swantastik is offline
Swantastik is starting off with a positive reputation.
Thanks, I took the piece's number I'll check that. It's look like black square box ? the fuse box Under the Hood ? Like you said, it Worth a try.
Old 10-05-2014, 01:45 PM
Nerky
Nerky is offline
Nerky is starting off with a positive reputation.
I just purchased a 99 F350 with a 7.3 in it. The radio was already out of it but I didnt realize why. Now I know it prolly has something to do with the leaky window problem I read about all the time on here. Im having an issue with my radio staying on plus my fan blower. Once I open my door I can hear a buzzing noise under my radio. Also sometimes my high beams work and sometimes they dont. Plus the light doesnt go off when I shut my door but a buzzing noise came from my fuse box so I pulled the small black relay out to shut the light off. oh yea the other day my horn just went of by it self so I had to pull the fuse on it so I didnt have to hear my horns blowing while I was going down the road. So I guess my question is could all this stem from the leaky window syndrome or could all these be none related and just be a pile of seperate problems?
Old 10-05-2014, 01:59 PM
jh818's Avatar
jh818
jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
As far as the dome light staying on, could be the door jam switch is stuck. Spray WD40 out of it to see if it helps.
Old 10-05-2014, 02:11 PM
riattadog
riattadog is offline
riattadog is starting off with a positive reputation.
radio and windows
hi saw an old thread by you. I have same problem with radio and windows not coming on right away after start. have 2003 V10 4 door F250 long bed.
was wondering if it is a relay that can be replaced.
thanks a lot
Old 10-05-2014, 02:33 PM
bourbondog
Yes you can replace it. Replaced the Accessory Relay (NOT the Accessory Delay Relay) in the fuse box to the left of the driver's feet inside the vehicle. I purchased Standard V13081 RY612 for a total of $15.61. It is black and square and has a two-prong plug in it. It makes everything wacky if bad.
Lincoln White
1997-2006 Expedition & Navigator
22
03-03-2017 08:27 AM
01FordEx
02-13-2017 09:35 AM
racin
1997 - 2003 F150
03-28-2016 09:02 PM
deputydog03
81
03-08-2016 10:20 PM
Schuyles
04-12-2012 09:06 PM
Quick Reply: Radio on by itself, now drain on battery?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
