I'm pretty sure you don't have a dana 28. What year and model truck do you have. SHould be either a 8.8" or a Dana 60 if its an 8 lug. Only other Rear ford used on our ear trucks was the 9 inch and that was only in the early 80's.
The F250 used a Ford/Sterling 10.25 semi floating or full floating axle depending upon GVWR, no Danas or 8.8's or 9". You can also ignore the year listed in the axle chart, those codes apply to all years in this generation.
The GVWR 8800 LB and Rear GVWR 6084 The tag on the rear has this numbers on it. V131C 10 10 2 7B26
Reason: more info
By the way does anybody have a set of tires for 16 or 16.5 rims? any kind of tires is good. when i bought my truck the guy gave me a set of tires that had four different things wrong with them.
