British Columbia British Columbia
Join Chapter, Leader: sky Cowboy
Need 7.3 diesel Mechanic in Lower mainland
Old 07-29-2011, 09:48 AM
DavidE's Avatar
DavidE
DavidE is offline
Anyone have a good 7.3 mechanic or shop to recommend in the lower mainalnd? Am having intermittent rough idle/running problem so want some that has 7.3 experience, analyzer,testing equip and ability to idenfity the fix without throwing parts at it at my cost. Thanks for your help.
Old 08-03-2011, 11:55 PM
DavidE's Avatar
DavidE
DavidE is offline
Don't know what to make of "0" "zip" "zilch" recommendations for mechanic in Lower mainland!!!
Is it because only people who do their own work are members here or no one wants to stick their neck out or no one has had good experience with a shop here or ????? This is supposed to be a place to get help from fellow Ford owners !!!
Old 08-03-2011, 11:59 PM
bigrigfixer's Avatar
bigrigfixer
bigrigfixer is offline
The Pacifier
This forum sort of gets passed over and forgotten. The only one with any real traction is the BS thread. Anyway...
Can't say that I know of any Powerstroke specialists. There's BD Power in Abbotsford. NW Fuel Injection in Port Kells, but they're mostly a fuel injection place, not really into just Powerstrokes.
Hopefully someone else will chime in for you.
Old 08-04-2011, 01:41 AM
FORD RANGER's Avatar
FORD RANGER
FORD RANGER is offline
howdy all,
what do you need to know? i can work on all diesels and gas. whats on your mind?
Old 08-04-2011, 09:30 AM
DavidE's Avatar
DavidE
DavidE is offline
Thanks for offer Jack. Posted symptoms of "Intermittent very rough idle" on 1999-2003 7.3 forum where I found I needed a mechanic or shop that had AE or similar equipment and ability to find the problem.. Can do minor maintenance but not electronic or heavy repairs so wanted someone here to go to for help when needed.
Old 08-13-2011, 09:00 PM
Lstanley's Avatar
Lstanley
Lstanley is offline
Don't take it to BD diesel in abbotsford their way overpriced. Trust me I took my 6.0 diesel there. Try PDR diesel in langley. Ive delt with them and they seem to know their ford diesels. How many miles on the truck? rough idle? very well could be a injector(s) going out on you.
Old 08-14-2011, 02:20 PM
FORD RANGER
your welcome dave. you could have an o-ring on the injector going south on you as well. i ran across that in a 444E afew times. they are similar to the power stroke.
Old 08-15-2011, 11:49 AM
DavidE's Avatar
DavidE
DavidE is offline
Thanks L Stanley for referral and again Jack. I've got 145k km or about 91k miles on the truck. Hope its not injectors so soon.
Old 08-16-2011, 12:28 AM
FORD RANGER
i have noticed that the o-rings on the injectors do go bad. thats why i said something.
Old 08-26-2011, 09:02 PM
Trophy_23's Avatar
Trophy_23
Trophy_23 is offline
You could try Precision Auto Services in Langley.... I have spoken to them a few times and had my truck in there once. They seem to have a decent diesel guy there. Worth calling maybe?
Old 08-29-2011, 10:03 AM
DavidE's Avatar
DavidE
DavidE is offline
Thanks for your help Trophy. I'd actually sent them an email about the same time as I posted my request for suggestions here. In light of your recommendation I will followup with them.
Old 09-03-2011, 12:16 AM
Lstanley's Avatar
Lstanley
Lstanley is offline
You could also try Bernhausen diesel in Langley. They also specialize in ford diesels. With that amount of mileage it shouldn't be the injectors. It may be as John said, o-rings. I still have my original injectors and have 4 hundred thousand km's on my 7.3 .
Old 09-03-2011, 12:48 AM
FORD RANGER
and its jack and the o-rings do go bad. the navistar 444e is similar to the powerstroke.
they have the same injectors. no worries. and when you start pulling injectors out it will flood the crank case with fuel. and let them power down for atleast an hour. because it takes 110 vac to fire them. the ecm has a power inverter in it. and change your oil too. it will have diesel fuel in it. and it may flood the cylinders as well. and or both oil and fuel so be carefull. don't hyrdastatically lock the engine up with oil and fuel.
Old 09-03-2011, 01:33 PM
DavidE's Avatar
DavidE
DavidE is offline
Need 7.3 diesel mechanic in Lower Mainland
THanks Lstanley. I'd actually emailed them about a month agao asking for info on how they would go about diagnosing and repairing my truck.
Got no response.
Thanks for info and help Jack.
Both replies much appreciated.
Sous
Missouri Chapter
01-08-2018 02:18 PM
Winmagbar
01-06-2016 12:05 PM
Willl
05-10-2014 07:53 PM
eddie a
11-25-2013 09:38 AM
DavidE
Washington Chapter
16
08-15-2011 01:16 PM
Quick Reply: Need 7.3 diesel Mechanic in Lower mainland
