Get Rid of Hard To Reach Rust
  #31
Old 09-09-2011, 07:48 PM
49fordpickumup's Avatar
49fordpickumup
49fordpickumup is offline
49fordpickumup is gaining momentum as a positive member of FTE.
Suggestions. If it is still cheaper to buy in gallon size and you will use a gallon size, someone suggested to me to buy a few small empty pint/quart paint cans and fill them full at the beginning, so you aren't exposing the gallon can to the the air, as it ages the POR-15. Also it was suggested if you have a garage refrig., store cans, as cold also slows down chemical action. There are many two part paints for our use and there is always someone who has had good/bad luck with each of them. I think preparation is the answer. chuck
  #32
Old 09-09-2011, 08:16 PM
59JEEPSTANG's Avatar
59JEEPSTANG
59JEEPSTANG is offline
59JEEPSTANG is starting off with a positive reputation.
I would not buy POR 15 in gallon size. Use quart size. Also, use a laddle to scoup out the paint being careful to not get any on the lip of the can. Before putting the lid back on put a piece of saran wrap between the lid and the can. POR 15 is good stuff, I have bought cans were the lid was stuck from the factory (usually this happens when it is the only can I have). Good luck getting the can open if you get paint on the lip.
Just wire brush and paint and your good to go.
Paul
  #33
Old 09-09-2011, 10:30 PM
lets7777's Avatar
lets7777
lets7777 is offline
lets7777 is starting off with a positive reputation.
I used rust bullet on a 65 Mustang with very good results. Only loose rust needs to be wire brushed off. If you are going to top coat the rust bullet, you should lightly sand it first.
  #34
Old 09-09-2011, 11:23 PM
429unibody's Avatar
429unibody
429unibody is offline
429unibody is gaining momentum as a positive member of FTE.
Just another POR15 coating We sprayed this on with a Wagner airless sprayer worked well you just have to move quickly,and clean the gun immediately
  #35
Old 09-10-2011, 10:40 AM
Buzz44's Avatar
Buzz44
Buzz44 is offline
Buzz44 has a good reputation on FTE.Buzz44 has a good reputation on FTE.
If I you are going to spray on por15 make sure to be in a well ventilated place. I would also wear a resparator as por contains isocyinates. Not sure I spelled that right but it has some not so good to breath stuff in it. Just my thoughts on spraying this stuff on. My truck was sitting outside when I did the frame so no problem with ventilation issues there. Oh hey is that a bowtie I spy in the post above this one? Whats up with that?
  #36
Old 09-10-2011, 05:23 PM
429unibody's Avatar
429unibody
It was my Dad's 87 GMC Wrangler which I inherited after he passed away! I'm building a show truck for my Sled deck business I will be running once I get my shop built
fordguy2100
19
01-23-2017 09:06 AM
jenkinsj
Paint & Bodywork
09-22-2013 03:44 AM
reed1951
08-04-2013 06:43 PM
COMPLIT1107
Paint & Bodywork
05-02-2010 08:16 AM
lmd91343
Paint & Bodywork
01-05-2010 09:05 PM
Quick Reply: Get Rid of Hard To Reach Rust
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
