Help needed with Spindle bolt locking pin removal
Old 09-25-2011, 05:30 PM
longm's Avatar
longm
longm is offline
I need to replace the king pin and bushings on a 1964 Econoline Pickup and am have trouble removing the locking pins. The manual states that the pin just needs to be drived out, but mine will not budge. Any tips for removing the pin would be greatly appreciated.
Old 09-26-2011, 08:38 PM
GLR's Avatar
GLR
GLR is offline
I assume you took the nut off. It's a tapered pin, pound on the threaded side.
Old 09-27-2011, 07:10 PM
longm's Avatar
longm
longm is offline
Hi Gorge - that is the problem the 64' does not seem to have a bolt, just a pin. Since I need to clean up the axle, I will just remove it and have the pin pressed out at the shop.
Thanks
Mike
Old 09-27-2011, 07:39 PM
GLR's Avatar
GLR
GLR is offline
Just checked some pics. The pin is tapered so will only go out one way. Your 64 has the threaded top where the grease fitting goes. You have to be careful driving the pins out or the threads in the spindle can be damaged. Don't ask how I know.
Auger Hekla
08-19-2017 02:58 PM
lebo337
04-22-2013 07:45 PM
windsor8689
02-15-2011 09:26 PM
tazmania18235
04-21-2005 04:49 PM
tasha01
11-23-2004 01:44 PM
Quick Reply: Help needed with Spindle bolt locking pin removal
