Temporary fix for exhaust manifold leak. Worth it? - Ford Truck Enthusiasts Forums
Old 11-21-2014, 07:46 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Air Intake and Exhaust Guides
Print Wikipost
Old 09-04-2011, 03:31 PM
aerodj1
aerodj1 is offline
aerodj1 is starting off with a positive reputation.
Part of my exhaust manifold gasket blew out at the #8 cylinder on my 89 351W. How it happened is a whole other story in and of itself, but now I'm trying to figure out what to do.
I bought the truck a month ago knowing that I was going to have to replace the exhaust system, so I started saving money, expecting to drop it off at the shop around the middle of October. Now I have a leak that is bad enough that I can feel it by hand near the port. Performance is not affected, but it sounds like hell driving thru my neighborhood. I have three options, and am looking for opinions. Keep in mind, all of the emissions stuff has been removed, and it's my mudding / run to Lowe's truck. By no means a daily driver.
1. Use the Permatex High-Temp patch kit. Claims to work. Should carry me over until I can afford to bring it in.
2. Leave it as is and keep an eye on it. Runs fine, and I'm not sure I want to goop glorified JB Weld on, as I can only imagine the added labor for clean up when the time comes.
3. Park it and wait. This is a last resort, as I have several missions planned over the next 6 weeks.
What say you? Thanks for any input you can provide.
Ryan
Old 09-04-2011, 03:44 PM
400 .040over
400 .040over is offline
400 .040over is starting off with a positive reputation.
replace the gasket
Old 09-04-2011, 03:47 PM
86F150302's Avatar
86F150302
86F150302 is offline
86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.
Put a new gasket on. Took me like 2 hours to replace both mine.
Old 09-04-2011, 03:50 PM
Jaime74656's Avatar
Jaime74656
Jaime74656 is online now
Jaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to behold
i would put a new gasket on and if your going to redo exaust (well if i was) I would do that at the same time honestly...make less work for my self when ever possible!
Old 09-04-2011, 07:36 PM
aerodj1
aerodj1 is offline
I'm an aircraft electrician who knows just enough to get into trouble when it comes to cars. How can a guy pull the manifold without busting bolts? I don't have a torch...
Old 09-04-2011, 08:09 PM
ChristopherN
ChristopherN is offline
ChristopherN is starting off with a positive reputation.
Very carefully with PB blaster, or just prepare yourself and get a couple of easyout's.
Old 09-04-2011, 08:10 PM
L. Ward's Avatar
L. Ward
L. Ward is offline
L. Ward has a good reputation on FTE.L. Ward has a good reputation on FTE.
soak the h e double hockey sticks outa them with PB Blaster. Do this over a couple days and they should come right out.
Old 09-04-2011, 09:11 PM
Jaime74656's Avatar
Jaime74656
PB blaster and plunty of it as L. Ward said...just drench it and carefully proceed so what if you use three cans on them? its worth it if they come loose even WD40 would probably help too...
actuall mileage may vary depending on rust and other factors...
Old 09-04-2011, 09:42 PM
aerodj1
aerodj1 is offline
Thanks guys! Looks like I'm going to the parts store tomorrow.
Old 09-04-2011, 09:48 PM
Eddiec1564
Eddiec1564 is offline
Eddiec1564 has a great reputation on FTE.Eddiec1564 has a great reputation on FTE.Eddiec1564 has a great reputation on FTE.Eddiec1564 has a great reputation on FTE.
When you do soak them bolts down and start the engine up, just don't mind the smoke from the PB blaster as the manifold heats up! Do a few heat cycles and when its cooled off respray them and those bolts should come right off. Also use a good 6 point socket so it gets the best bite on the bolt heads with out rounding them rusty things off.
jpilk99
1999 to 2016 Super Duty
05-09-2017 11:29 PM
mprimi
1968-2013 Full Size Vans
04-06-2017 12:54 PM
Tparkin99
25
12-19-2016 01:16 PM
JLuskin
08-26-2015 01:18 PM
BuckHammer
22
03-15-2011 08:21 PM
Quick Reply: Temporary fix for exhaust manifold leak. Worth it?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
