...brake lights stay on...
I'm new here...need some help...54 F100 with 350/4spd and stock everything else...sits in the garage for long periods of time...an interesting quirk has developed...the brake lights tend to stay on all the time...sometimes I can mash the brake pedals 3 or 4 times and they will go off...after that they will mysteriously come back on by themselves sometimes...I changed the switch...didn't make a bit of difference!Is this a brake problem or an electrical problem?Thanks!
Is the brake light switch in the master cylinder or a linkage to the pedal? If it is in the master cylinder it is probably broken internally sticking in the on position. Ford had several years where the switch would leak internally and actually cause a fire because contaminated break fluid (or possibly even clean brake fluid ) would cause heat build up . (My 1994 F150 had that- I was changing my oil and the switch on the master cylinder started to smoke! - I am sure it was a lucky coincidence but kind of exciting none the less).
The switch is in the master cylinder,which is on the frame under the floor...there is a tailpipe right next to it...I wonder if it IS a heat related issue.It is almost 100 degrees today...but this happened last spring,too...maybe it's the tailpipe.Might be time to fabricate some kind of heat shield.
Some of the new switches aren't any better. I finally broke down and got one from the local Harley Davidson dealer. His parts jockey didn't know what I was talking about, but his mechanic finally got him straightened out. Prior to about '92 HD used a similar switch with the same 1/8" npt thread and made in the USA - and cost accordingly.
I've had no problems since......... fwiw
If you swap out the switch and that doesn't help, take a very close look at that continuous hot wire (even when the ignition is off) and see if its touching any other wire. This happened to me back in the spring and ONE single strand had fallen over on the wire going to my tail lights. It drove me crazy because my lights would not turn off unless I pulled the battery cable.
