79 f100 starting problems - Ford Truck Enthusiasts Forums
Old 09-03-2011, 07:19 PM
skotrod1
skotrod1 is offline
skotrod1 is starting off with a positive reputation.
Hi, Going through this forum I've found a lot of good info. I hope one of you can give me some idea or cure for my starting problem. I have a 79 F100 302 AT 2WD. The truck on occasion will turn over and start but when I back the key off to the run position the truck shuts off. Eventually it will stay running and not give a problem for a few days. Today I went through this and when I got home I shut the truck off but had power to the dash, a light (I didnt pay attention to which light) was on. I tried the key again, light stayed on, I disconnected the battery. Over the past couple of weeks I've changed the Ignition switch, A new Ign module from NAPA, cleaned the contacts to the coil, The starter solinoid is new, the Alt has been changed to a 1 wire with internal voltage reg. I've checked the fusible links OK. When the truck is in the fail mode there are 2 red wires with green tracers from a terminal on the back of the ign switch, one of these gets so hot it will burn your finger. Thats about it, any ideas would be appreciated. Thanks Skotrod
Old 09-04-2011, 10:17 PM
skotrod1
skotrod1 is offline
I'm surprised no one has offered up any info. I know there are a lot of similar treads but none answer my problem. Any ideas? Thanks again, Skotrod
Old 09-05-2011, 02:09 PM
skotrod1
skotrod1 is offline
Bump, someones gonna post sooner or later.
Old 09-05-2011, 04:38 PM
Richtertrevor78's Avatar
Richtertrevor78
Richtertrevor78 is offline
Richtertrevor78 is starting off with a positive reputation.
With all the new parts you have thrown at the truck, recheck the grounds to the parts you changed out. When I first got mine, I caught hell figuring out that my starter was grounding out from the inside wiring touching the frame of the starter. All kinds of wires got hot and all I did was replace the voltage regulator and starter solinoid. It seems like ground will be the cure (and not a wire), a screw that is also the component ground. Some of the screws going into fender walls seem tight but still kind of have some play, they are more important than they look. Hopefully its that easy.
Old 09-11-2011, 04:58 PM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
Sounds like a problematic connection at the ballast, which is responsible for powering the ignition coil when the key is turned to RUN.
The fact that there is a wire getting so hot that it burns your finger means you need to disconnect the battery, and not reconnect it until you have solved the problem. The wire that's getting hot sounds like it is the ballast. Does it say "DO NOT SPLICE?" If so, that's the one. It's highly likely that the two issues are related. My guess would be the ballast is shorted to ground somewhere along the wiring harness. 9 times out of 10, this is because someone has modified the truck's wiring somehow. Start checking.
Old 09-12-2011, 10:05 AM
JoeHarbourJets
JoeHarbourJets is offline
JoeHarbourJets is starting off with a positive reputation.
skotrod: you wrote: "When the truck is in the fail mode there are 2 red wires with green tracers from a terminal on the back of the ign switch, one of these gets so hot it will burn your finger."
Are both these actually wired to to the switch? I don't have a 79 myself, and something may be different from mine, but I think there should only be one red/green wire, which I'm pretty sure goes to the instrument lights.
Old 09-16-2011, 08:35 PM
skotrod1
skotrod1 is offline
Ive been real busy the past couple of weeks and hav'nt had time to keep up with the forum or work on the truck. Thanks for the reply's, Ill try to check on some of the suggestions. joe harbor jets, yes both wires come from one terminal on the back of the ignition switch, all I have is a haynes manual and the wiring diagrams are not detailed enough, and I don't really trust them to be 100% accurate.
Rwm8082
01-30-2017 01:39 PM
cushing
01-10-2017 01:36 PM
kujo3692
08-16-2016 06:49 PM
scottlathrop
03-16-2016 11:00 AM
scalhoun
02-10-2001 10:40 PM
Quick Reply: 79 f100 starting problems
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
