speedo and odomiter quit working....and HARD shifting
With the year of your truck, your speedo, should be cable driven. Thus if it was just the VSS your speedo would still work just fine. But, with speedo not working, I bet that your VSS is still good, just that it may be missing the little gear on the end of it. Or the gear is missing some teeth.
Pull codes, if you get a VSS code, unbolt and pull out the VSS and see if the gear is still on the end of it. If it isn't you'll have fun fishing that plastic piece of chit out of the tail shaft
speedo holds steady, rabs is still unplugged...radio was off during testing...
replaced with a 15 amp fuse.....
thought for sure i had this thing beat!....took the wife for a ride to show her it was fixed....lol wow that backfired, started shiftin hard as before...but atleast gauges work and its semi-drivable...its back to the pre-gauge failure of shiftin weird when it wants to lol.. it drove perfect for my initial run. dunno what happened withinin the 1/2 hr of waiting to show her but it is what it is
I have a similar issue. My speedometer/odometer stopped working after I replaced the heater core last weekend. I had to remove the metal box (about 4x6x1) that was behind the glove box while replacing the heater core. now my speedometer does not work. Was this the RABS box? Unplugging it does not seem to affect the speedometer.
This was on a '92 F250, 5 spd, diesel.
Programmable Speedometer/Odometer Module. It's located on the back of the instrument cluster. It divides down the signal from the VSS in the rear axle to something the speedometer/odometer and PCM can use. It eliminated the VSS in the tailshaft of the transmission/transfercase around 1991.
I suppose if you could find a wiring diagram you could see if the signal is making it to the PSOM then see if the output signal is there.
PSOM on back of the instrument cluster:
VSS-RABS-PSOM wiring diagram:
