View Poll Results: Which Thermostat Do YOU Run
180* Thermostat
7.00%
195* Thermostat
41
41.00%
203* Thermostat
47
47.00%
It really doesnt matter...
5.00%
Voters: 100. You may not vote on this poll
203* Thermostat
#106
What he is saying is temps while towing are higher than the set points of all the thermostats so it shouldn't make any difference which one you are running because any one of them would be fully open anyway. Seems logical but I see jhl3's point as well, the ability to cool down for the next grade.
#107
So are the long stems just for the IH Pumps ? Not sure I'm following correctly. Im running a stock pump. I think a few years ago i put in a 203 and would really like to go back to 193 or even 180. Its hot here most of the year. Just want to make sure i get the proper length for the stock pump, I will decide on temp.
Short stem = IH style pump
They are not interchangeable, or so I have been told by reputable sources.
#108
What baffles me is the difference in operating temps some experience with different thermostats. The only think I can think of is the difference in stem sizes or possibly different passage sizes. I don't get it......
#109
#110
#111
#112
I get that is what's being said, but I am here with firsthand experience to say it does not work that way. There is a reason I pulled over into a rest area in the middle of a long pull up a 6 percenter to change my 203 back to a 180. My oil temps were sky high for what they should be. The 180 made the difference. There are a few others on here that tow heavy and went the same route with the same result. If the temps always ran at a certain temp no matter when towing or not, then what would be the point of a lower temp thermostat? My 180 does not allow my temps to go higher when towing. that was the whole point of changing back over. Anyways, semantics I guess...
#113
on
There is one additional thing that is missing: What does the second spring and disk on the bottom of the long stem thermostat do exactly?
On the 180*F t-stat, there is almost no tension on the disk when compared to the 193* and the 203*.
Yes, that was the point I failed at making. But even on the "cool down" for the next grade the EOT is still not dropping below 210, so both thermostats will still be fully open......I don't get it. But if it's working for him thats all that really matters. I just can't figure out why in my head
Again, there is nothing visibly different to my middle aged eyes. I'll have to use a set of calipers to measure the openings and, due to your valuable input, the stem/shaft. Having stated that, I still would like to know what the lower, smaller spring controls...unfortunately, my mind never gives a break...
_
#114
When the thermostat is closed there has to be some way for a little bit of water to circulate. On my old Cummins 400 in my heavy truck it was a little poppet kind of thing on the edge of the thermostat. What does this engine use? Is it possible that that weak spring lets the T-stat open a smidgen to let water through when it is otherwise closed?
#117
203 Long Stem from Dieselsite. I have never used a short stem. I have removed a few, but would not use one. Imagine changing a thermostat on a REALLY hot engine under duress of towing a grade....not fun...LOL
#119
Sbroom
06-03-2013 08:49 PM
mundamanu
04-05-2004 02:26 PM
