Driveline noise all speeds
2004 F250 5.4 4WD 10.5 Sterling. I am hearing what I would describe as a consistent rhythmic whirring at all speeds, acceleration/deceleration, braking/coasting and so on. I can’t seem to make the sound change in severity, only in speed when slowing down or speeding up. I have replaced all 4 wheel bearings, calipers, pads, rotors, backing plates and installed warn manual hubs.
Would an issue with the rear diff be consistent with these symptoms? I feel like load would make the sound change so I am unsure where to go next.
I replaced the parking brakes 18 months ago along with the rear dust shields/plates.
Any help or pointers on where to go next is greatly appreciated.
-Colin
-Colin
A carrier bearing (if your truck has one), or a bad pinion bearing will make constant noise, changing with speed.
Jack the back end up, and spin a tire by hand (may have to block the opposite tire, so that the driveshaft will turn), and listen.
You may be able to pinpoint where the noise is located.
BuckeyeF250
05-27-2008 09:18 AM
