Go Back  Ford Truck Enthusiasts Forums > Misc. > Offroad & 4x4
Reload this Page >
Tools or parts youve built YOURSELF
Old 09-01-2011, 11:21 AM
alpha/omega's Avatar
alpha/omega
alpha/omega is offline
alpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to all
I dont want to see pics of half arsed traction bars, bumper mounted jib cranes or a little bend put in a box wrench. Post up some real tools, shop items or parts BUILT BY YOU (not by some guy you know) to make your life easier or work better.
I guaran****intee by page 2 some idiot wont read the above and post and will have a pic of a rusty piece of angle iron bubble gummed under a rusty frame to lower their spring hangers but this IS NOT what this thread is about.
Post up some good stuff if its possible from FTE.
Old 09-01-2011, 11:22 AM
alpha/omega
Also, THIS is not a built by you tool for removing an oil filter
Old 09-01-2011, 01:21 PM
fatdan460
fatdan460 is offline
fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.
meh, you don't need fancy tools when you do the job right :flipoff:
about the only times i've ran into spots where i could rig a spare tool to do the job better was when i was cutting corners to hurry up on a job. and i really haven't done any major work since getting my welder, so no home built tools.
do ground down "thin" wrenches count?
p.s. did you ever finish and try out your press?
Old 09-01-2011, 01:40 PM
alpha/omega
Yeah, it works pretty damn good. I still need to rig up a pneumatic foot control and Id like to find a 30 or 40 ton air over hydraulic to replace the 20 ton air over hydraulic Ive got now. The press takes all 20t and laughs though. I have absolutely zero deflection in the bed or the beam at full weight. Ive seen 3/16-1/4" deflection in a Norther Tool (Big Red or Arcan I think) Press at 20 ton - granted its a $300 cheapo press.
I have about $30 in mine and about $10 in different attachments Ive made.
Im going to attempt to build a press brake but I may just buy the HD kit without a backstop from this guy on Pirate and weld it myself.
Swags site: http://www.swagoffroad.com/20_Ton_Press_Brake.html
Pirate link: http://www.pirate4x4.com/forum/showthread.php?t=867375
Old 09-01-2011, 05:53 PM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
i don't have any tools here, they are all in the old shop.
i made a lot of wrenches out of flat stock and a plasma cutter.
Old 09-01-2011, 06:20 PM
kjett's Avatar
kjett
kjett is offline
kjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to behold
I'll have to get a pic, but Nick and I made a few spindle pullers to attach to a slide hammer. Makes changing axle shafts much faster and easier when you don't have to fight with getting the spindle off. Not anything special, but functional. We have one for a D60, D44, and D35, with a total cost of about $10
Also, I've made some tools for machining barrels on a lathe. Special cutters and broaching tips mostly.
Old 09-01-2011, 06:43 PM
alpha/omega
Let's see this *****!
Old 09-01-2011, 06:50 PM
77mud's Avatar
77mud
77mud is offline
77mud has a very good reputation on FTE.77mud has a very good reputation on FTE.77mud has a very good reputation on FTE.77mud has a very good reputation on FTE.
Does my 5/8's wrench door handle that i made cause i got tired of breaking the plastic POS ones count?
Old 09-01-2011, 07:26 PM
kjett's Avatar
kjett
kjett is offline
I'll get pics of the spindle pullers this Friday night. They are sitting in Nicks shed. Seems he has more of my tools down there then I do up here including both of my welders.
Old 09-01-2011, 08:00 PM
alpha/omega
Yeah, post it up!
Makes sense because he does more wrenching on your stuff than you do.
Old 09-01-2011, 09:16 PM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
khadma has a brilliant futurekhadma has a brilliant futurekhadma has a brilliant futurekhadma has a brilliant futurekhadma has a brilliant futurekhadma has a brilliant futurekhadma has a brilliant futurekhadma has a brilliant futurekhadma has a brilliant futurekhadma has a brilliant futurekhadma has a brilliant future
Do they have to be auto related only tools?
Old 09-01-2011, 09:51 PM
fatdan460
naw, homemade tools are tools regaurdless of intended use, as long as it isn't a homemade hitch mounted jib crane that you use to pull up your girdle
Old 09-02-2011, 07:59 AM
kjett's Avatar
kjett
kjett is offline
Here are some useful homemade tools:
The pressurized wine bong:
The drunken BBQ spatula and tong set:
And a couple of tools (but not useful):
:/flipoff
Old 09-02-2011, 12:35 PM
mark a.'s Avatar
mark a.
mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
I've made a few things over the years. This is a puller I made for Dana 60 & 70 differential side bearings. Anyone that works on them knows how damn expensive one is to buy. You put the round piece in the axles hole in the carrier so the puller has something to seat against, put the 2 halves together around the bearing then the hose clamp, bolt the puller to the top and remove it. It's never hurt a bearing.
Old 09-02-2011, 12:57 PM
lucky_thirteen
lucky_thirteen is offline
lucky_thirteen is starting off with a positive reputation.
Edit: I fail for not reading the entire OP :flipoff:
Quick Reply: Tools or parts youve built YOURSELF
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
