im in process of making a front hub puller for my 4x4 hubs they r very exspensive to buy and im poor i will send a pick when im done...im sure someone has done this before
thanks 73 ford guy im new and a little slow at this im going to pull her all down this weekend . that picture was exactly how i was thinkin of making one so now i know it will work
heres a case speader I made today. Worked really well. Had too much backlash but case was tight so I used this to spread it, and added a small shim to put gear closer to pinion leaving me with good bearing preload, .012 backlash and a good pattern. All for the cost of w/e i hoarded out of my shop.
Now off with the setup bearings and time to press on some freshies and wrap this up.
The table i got you dont just pick up by your self .....
6x6's for legs its banded with 2x10's and its got 2x6's for the top.... needless to say you could put 3 or 4 460's on it (thats the size of it) and prolly stack them and never 'flinch' it as he said...
