fuel pumps
Old Sep 1, 2011 | 12:05 AM
miniracer's Avatar
miniracer
fuel pumps
hi i have 1984 ford f250 4x4 4 wheel drive
i had the front tank pump replaced the truck ran
for a day then on my way home it seems it was running
out of gas,
i have a clear fuel filter by the carb it gets gas then
it stops
i have reset the fuel pump reset button
and it stills does it
any i deas
allso im on uneployment and can
i use my electric pump Holly
from my race car
its 7 to 14 pounds of presure
i do have a oil presure shut off switch
Thanks
Old Sep 1, 2011 | 07:22 PM
Franklin2's Avatar
Franklin2
You must have a 460 equipped truck. You need to check the oil pressure switch and the fuel pump relay. If you are considering running and wiring up a aftermarket pump, why not just hot wire the factory pump with a switch? You would be accomplishing the same thing.
bigbird189
Jun 5, 2016 11:49 AM
colorado hick
Jan 2, 2016 03:32 PM
Aaron M Sholley
24
Jan 8, 2014 07:47 AM
85 250 L MOTOR
Jan 26, 2010 07:38 PM
gearshift101
Oct 26, 2004 05:12 PM
