Fuel Pulse Dampener/Accumulator Replacement - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-30-2011, 04:09 AM
Enginuity
Enginuity is offline
Enginuity is starting off with a positive reputation.
Talking Fuel Pulse Dampener/Accumulator Replacement
Hey Guys,
This is just a little thanks for all the useful hints I've gotten on the forum. I recently noticed that the Pulse Dampener/Accumulator (Ford P/N: F6TZ-9N163-AA or Bosch P/N: 9 401 240 169) on my '96 F250 7.3 PS was leaking diesel. Actually leaking is a huge understatement... there was a 1/4" wide spray of diesel pulsing out like a severed artery!
Anyway, everything I read talked about removing the turbo (and the associated woes) which I really, REALLY did not want to get into that.
So it may have been the long way around but I was finally able to fabricate a tool that allowed me to remove the accumulator without the taking off the turbo.
I've pasted some pix to help anyone interested in making their own - you'll probably need at least two (at different angles) in order to account for the limited available turning radius. Maybe it's just me but I'd rather make something new in my garage than fight rusted on bolts and nuts while cramped under the hood.
Hope it helps...
Old 08-30-2011, 04:55 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
You are more determined than I...I would have pulled the turbo myself.
welcome to FTE. stay and hang out. Hide your wallet
Old 08-31-2011, 12:02 PM
Enginuity
Thank Tylus
Determined or hard headed? Probably more the latter! I just saw a bunch of threads talking about hard to get to bolts, broken studs, etc... Keeping my fingers crossed though as it appears there's now a small leak coming from the banjo bolt! Hopefully, I'll be able to snug it up and be off and truckin'.
Thanks for the welcome!
Old 12-03-2016, 02:08 PM
timmosazz64
timmosazz64 is offline
timmosazz64 is starting off with a positive reputation.
I know this post is from way back but do you remember what size the wrench was? It looks like 1".
Old 12-03-2016, 04:03 PM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
RV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputation
A crow's foot with an extension wouldn't fit? Your tool reminds me of that.
Old 08-30-2018, 07:52 PM
Henry Suden
Henry Suden is offline
Henry Suden is starting off with a positive reputation.
Hey guys, iIm here with a related question of sorts. If I were to want to tighten my banjo bolt would I have to remove this accumulator? On other FTE blogs this doesnít seem to be a very common addition, and I havenít found much help. Most guys put their combo wrenches through the front webbing of the turbo pedestal, but it isnít possible on these California models obviously. Anyways, if you guys have any ideas I would certainly appreciate it. Thanks
CR Dan
18
10-17-2017 08:31 PM
WIREPULLER
19
10-10-2017 02:20 PM
sflem849
81
02-26-2017 08:37 AM
96_F250_Deezal
07-23-2016 04:16 PM
Archion
06-14-2016 08:02 PM
Quick Reply: Fuel Pulse Dampener/Accumulator Replacement
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
