1993 Ranger Transmissionn
OK I'm trying to get my transmission out of my 93 Ranger XL 3.0 LTR. But the quick disconnect is all messed up. the plastic ring will not go in to release the hydraulic. How can I get this off? Also do I really need to remove the clutch master cyliner fromthe cluch pedal. That seems like a lot off extra work.
Thanks;
Paul
Thanks;
Paul
transmission
You should be able to pull the ring off without damging it. If you can get it off you just need to get some carb or brake cleaner and some WD40. What had more than likely happened is there is dirt and crap in it nhot allowing the ring to disconnect from the slave cylinder.
Kijutsu
1983 - 2012 Ranger & B-Series
19
11-29-2007 08:34 PM
Otherside
01-02-2004 09:30 PM
cpc101
03-25-2003 10:27 PM
