Sam , I gonna buy these adapters
fit 5x5.5 hub to 5x4.5 wheel
6061 T6 aircraft quality billet aluminum
1" thickness
1/2"*thread size studs**
CNC machined
open end lug nuts included
Is that a good fit ? Please let me know . Thanks -Meir
1" thickness
CNC machined
should be fine.. , stock trucks had lots of tire/fender clearance.
Where did u find the 1/2 x20 thread studs?
my adapters are 1.25 thick..
do they also tell u the center opening size? sometimes the axles have large center bores..
Hub Side Bolt Pattern: 5x5.5 inch (i.e. 5x139.7mm)
Wheel Side Bolt Pattern: 5x4.5 inch (i.e. 5x114.3mm)
Thickness: 1" (25mm)
Stud Thread Size: 1/2"-20
Open End Lug Nut Thread: 1/2"-20
Center Diameter: 88mm
Outside Diameter: 175mm
Torque Specification: 80 ft-lb
Note: Occasionally when hub studs protrude beyond wheel mounting surface on the adapters, they may need to be trimmed
