Is this normal ?
Old Aug 28, 2011 | 03:19 PM
1990FordF250Diesel's Avatar
1990FordF250Diesel
Question Is this normal ?
When my 7.3 IDI Diesel is idling, there is a light stream of grey smoke that comes out of the exhaust pipe.
There isn't lots of it, just a little bit of it.
It is worse when the engine is cold, but is still there when it is fully warmed up.
The engine has 286,000 miles, so is it just normal for a high millage diesel ?
Old Aug 28, 2011 | 03:54 PM
84-6.9L's Avatar
84-6.9L
Could be weak injectors, but have you cleaned your cdr valve in recent memory?
Old Aug 28, 2011 | 03:55 PM
ah1988's Avatar
ah1988
Is it just at startup, because if it is and then goes away it is normal if it is really dark and excessive and goes away i may me a gp or two or three.
Other than that idk. Look in the search box "smoke at idle" or "grey smoke while idle" ect. for this fourm and see if any threads show .
Old Aug 28, 2011 | 03:57 PM
1990FordF250Diesel
So grey smoke signifies a lean engine ?
Old Aug 28, 2011 | 04:47 PM
84-6.9L's Avatar
84-6.9L
No more then likely unburned fuel. Cause can be injectors not atomizing the fuel properly, if its spotting or come in bursts it could be a lone injector. But to start off with cleaning your cdr valve is the first step, it my be letting alot of oil vapors into the intake. The valve is located on the back of the intake manifold, it looks like a tuna can and is held on with two bolts, be careful when you pull it out there is a plastic stand pipe attached to the bottom that goes into the valley pan, so be careful not to crack it.
Old Aug 28, 2011 | 04:58 PM
1990FordF250Diesel
It is a steady stream, not puffs, so I'll clean out the CDR Valve tomorrow morning before going into town, and see if that works. If it does, that'll be great
Old Aug 28, 2011 | 06:55 PM
LSO1123's Avatar
LSO1123
I'm getting ready to pull my CDR off and clean it as well. I read that some use mineral spirits to clean them with. Anything else I can clean it with?
Old Aug 28, 2011 | 07:03 PM
Marianna2003's Avatar
Marianna2003
Does it have an odor? You should be able to smell unburned fuel.
Old Aug 28, 2011 | 07:24 PM
84-6.9L's Avatar
84-6.9L
carb cleaner will work.
James Garber
2015 - 2020 F150
Jan 18, 2017 03:46 PM
4inchlovin
Dec 5, 2007 10:05 PM
stroker7.3
Sep 5, 2007 04:22 AM
briansrapier
Jan 9, 2006 03:26 PM
kidoo
Aug 18, 2004 06:57 PM
