interior grab handle leaking water.... - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 08-28-2011, 12:34 AM
GreenballsFX4
GreenballsFX4 is offline
GreenballsFX4 is starting off with a positive reputation.
The upper plug that hides the bolt in the grab handle in the passenger side is getting water from somewhere. Anyone else have this issue or any other water leak issues?
Old 08-28-2011, 08:19 AM
lexustbs's Avatar
lexustbs
lexustbs is offline
lexustbs is gaining momentum as a positive member of FTE.lexustbs is gaining momentum as a positive member of FTE.
I had it happen once on the drivers side after using a high pressure washer to get bugs off my windshield. I think some water got between the seal, or some water leaked in around my cab lights. Either way it has never happened again.
Old 08-28-2011, 10:24 AM
F2502011
F2502011 is online now
F2502011 is starting off with a positive reputation.
check your weatherstriping around the door opening. sometimes one of the lips will get stuck under another lip and let water in.
Old 08-28-2011, 07:41 PM
btm991
btm991 is offline
btm991 is starting off with a positive reputation.
I had the exact same
Problem with mine when I first got it. It ended up being that the drain tube for the sunroof had been crushed when they put the foam or whatever they use into the a pillar.
Old 08-28-2011, 10:07 PM
hikeril
hikeril is offline
hikeril is starting off with a positive reputation.
I had the same challenge however I did not noticie until several months after I had the truck because it was garaged. I had the truck hooked up to my camper and it rained that night. As soon as I entered the truck I noticed water coming out of the passenger grab handle. Took it to the dealer which I new was going to be a challenge because it was going to be difficult to duplicated. Dealer called explaining the drain tube for the sunroof was not connected so whenever it rained it would enter the framing and run into the grab handle. Dealer said it was a simple fix.
Old 12-28-2017, 09:26 PM
Jde2466's Avatar
Jde2466
Jde2466 is offline
Jde2466 is starting off with a positive reputation.
Any update on this? I am having the same issue. Truck is supposed to go back to Ford next Thursday.
Old 12-29-2017, 06:07 AM
djousma
djousma is offline
djousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to behold
No updates. Its a thread from 2011. But as they mentioned, its common for the sunroof drains to clog too.
Old 12-29-2017, 07:41 AM
capt caper
capt caper is offline
capt caper is starting off with a positive reputation.
My windshield installer screwed up once and it leaked and the water came down the grab handle. So if a recent install was done the windshield seal is leaking. It is nosier as well at highway speeds.
Old 12-30-2017, 01:43 PM
WoundedVet's Avatar
WoundedVet
WoundedVet is offline
WoundedVet is starting off with a positive reputation.
This happened to me, too. It was the drain tube from the sunroof.
Easy to correct
Old 01-01-2018, 09:50 PM
Bunyon's_Ox
Bunyon's_Ox is offline
Bunyon's_Ox is starting off with a positive reputation.
I've got this problem but no sunroof in my truck. I've checked the seals around the door and they look fine. Does it if it has been sitting in the rain or a heavy dew but not when raining while going down the road. I suspect it is a leak at the top of the windshield and that's why it only leaks when it's been sitting wet, not running down the road. Any product that can be used to seal under the black rubber trim seal of the windshield?
Old 01-13-2018, 09:06 AM
cangim's Avatar
cangim
cangim is offline
cangim has a good reputation on FTE.cangim has a good reputation on FTE.cangim has a good reputation on FTE.
Any tricks or learnings from previous on these drain tubes? I need to blow mine out, think they have dirt and possible ice as the passenger side is always shaded they way I park normally, course, yesterday I backed in. I am not finding many pictures of this drain tube so will be taking some as I go today, unless it seems I can simply blow them out.
GN1220
1999 to 2016 Super Duty
22
01-09-2019 02:04 PM
jle70
05-23-2017 12:30 PM
wikdwest
04-01-2017 11:51 PM
troverman
2017+ Super Duty
16
02-17-2017 04:17 PM
troverman
2017+ Super Duty
16
07-14-2016 02:02 PM
Quick Reply: interior grab handle leaking water....
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
