Bearing Cap Seized to crank...Mystery needs solving
Please , I need some help Solving a problem... Quick background-
My 2011 F-250 6.7 truck 125k miles,died while towing a trailer on the freeway. I had towed to the dealership and torn apart. They found Metal in the pan so the motor was pulled to diagnose the cause. The mechanic found that
The bearing cap is seized to the crank and significant bearing damage to other bearings.
and my motor is shot.
The oil was changed 6k miles prior and was near full
Can anyone think of a Reasonable cause for this to happen?
Warranty company is trying to say I Had low oil Level and not cover it. But I checked the oil immediately upon breakdown and it was fine.
I have limited knowledge about motors and need help presenting my counter argument showing other possible causes. Any help will be greatly appreciated.
No fault codes
[byU QUOTE=senix;19443453]Think you are going to need the tech to state what the oil level was prior to tear down.
Thank you I will check if they tested the pump. No codes and oil level was a little over a quart low
I am going to have to confirm that he checked the sump.
i gave them the maintenance records, oil changes every 7k
You probably need to copy the oil change recommendations per ford to show you follow the schedule.
Is this an oil pump issue or oil sump plugged up issue?
Were there any codes stored in the PCM?[/QUOTE]
who was the "warranty" with?? anything other than ford and you might be screwed..
most of the non factory warranties are mostly junk.. they will find as you are already seeing, reasons to deny the claim.. If you do a search I bet you will find the bearing issues was a know items on the 12's and some 13's as well. good luck.
Thanks guys
Yes it is a aftermarket warranty company, I think that i need to hire someone to go down to the shop and do a analysis and test the pump and check for clogged sump And lines and document what they find. So that I have support for my fight, Otherwise I have to buy a new motor. If that is the case I’ll be asking you guys recommendations on getting a used motor and install.
Thanks again for the help
Also, the 6.7 bearings are tangless. Tangs on bearing do not prevent bearings from spinning. The tangs are only use for locating. Bearing crush is what prevents bearings from spinning.
I was thinking i had seen that on powerstorkhelp.com bill hewett in atlanta.. he has gotten some and it seem like i remember them being an issue with bearing and journal problems. not a lot but if it yours to goes pop you are not happy.
I hope the OP get this taken care of but i suspect it will be a battle for sure..
hope he will let us know how it going with the Extended warranty guys and who they are.. ?
Not sure where you got this info but on this forum there have been only a very few 6.7 engines with bearing problems. I am not aware of any 6.7 year engines having any bearing problems.
1st US Auto Protect
1st US Autoprotect
is the Warranty Company,
I will keep you guys posted.
I Get off work in a couple days and I will head over to the dealer .
I don't think your oil had anything to do with this failure. This is the reason I wouldn't own a 2011 6.7. I had a customer that bought a 2011 with 88,000 miles. Right about 130,000 his blew going down the highway. He blamed the oil I put in it but I pulled a sample and sent it in and the lab said the oil was fine. It didn't even have metal in the oil. I believe his dropped a valve and destroyed just one cylinder. He was an older guy that drove careful. On the flip side i also have another customer that has well over 200k on his 11 with no major issues. Just my $.02
Thanks WillyDMax for the input
That is a great point.
I just got off the phone with the warranty company and they ar saying the claim is denied due to “lack of lubrication “
I explained that there are no fault code lights recorded and I added 1.5 -2 quarts on the side of the freeway when I was broken down and when the mechanic got the truck he said it was 1 qt over filled.
the mechanic also said that the truck would have to run with about 4 quarts or less of oil to have no lube And cause this kind of damage.
which obviously would have recorded a fault code.
im at a loss on my next course of action.
any ideas?
any ideas?
